How do I tell labciew to make the robot kick once?
I am a noob at LabVIEW. How do I tell the robot in LabVIEW to kick the ball?
We are using motors. And I want to move forward for 1 second and then kick the ball. How do I do it? Thx Kyle Lenox |
Re: How do I tell labciew to make the robot kick once?
You're definitely going to have to give us more info than that.
How is your kicker set up? What motors does it use? How do they affect the motion of the kicker? How is it latched? What ports does its motor connect to? ... |
http://www.chiefdelphi.com/forums/sh...ad.php?t=81938 Like 1075guy said and others have said, we need to know more about the hard ware you are using to kick the ball. If you were going to control the motors manually and not through LabVIEW, What actions would you need to do to kich the ball with your hardware? If you can write the steps down and post them then, I am sure one of us could tell you how to code it. |
| How do you make the robot turn a perfect 90 | eccmaster | Programming | 2 | 16-01-2008 20:54 |
| How will the Balls Change once FIRST Paints them | Mr.G | General Forum | 28 | 24-01-2006 23:07 |
| how do i tell to the edurc when the remote is on. | Code\\Pilot | Programming | 4 | 28-01-2004 21:00 |
| How do you tell whether your sensor is detecting a crate or the diamond plate? | Greg Ross | Technical Discussion | 4 | 13-01-2003 19:02 |
| ONCE AGAIN, EVERYONE TELL ME THE ANSWER! =) | archiver | 2001 | 2 | 24-06-2002 02:42 |
