Go to Post unless your team is incredibly beastly, completely ignore the words "cool factor". Coolness does not outweigh functionality. - Sam N. [more]
Unread 19-02-2010, 17:18
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Autonomous Programming
This is what we're trying to do:
Use the optical encoder, in place of a joystick, to control the motors, by setting the motors to perform different actions when the encoder gives back a certain reading.
How exactly would we go about doing this?
Unread 11-03-2010, 14:05
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Smile Re: Autonomous Programming
When I was programming our autonomous I used the Delay and Feed block under the watchdog blocks and just passed the Error reference in between the bits of code I wanted to have execute. I'll try to post a example of this as soon as I can.
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 11-03-2010, 16:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Use the encoder value as the input to a case statement. Name the cases as ranges like "0..2499" and "2500..6999", and set the motors appropriately in each case.
Either put the whole thing in a while loop, or use Autonomous Iterative which calls your code repeatedly.
autonomous programming solomason519 NI LabVIEW 4 10-03-2009 12:30
CMUcam autonomous programming kshot Programming 1 17-01-2005 19:18
Autonomous Programming Guide cbolin Programming 2 16-12-2004 15:13
Autonomous programming Dush Programming 4 20-02-2003 09:54
autonomous sensor programming ? Laura_d Programming 1 10-02-2003 17:46
