We are having troubles with out Crio we have tried virtual every thing it will keep dropping the code every sec.
Post any ideas we will try them all (with in reason) if we don't fined out I don't know what we will do. Last edited by Twisted eric : 19-02-2010 at 18:02. Reason: clarification |
Re: Crio problems
Heres an idea, is the crio faulty? have you tried to see if it even works on its own? i know u probably already tried this but its an idea.
Re: Crio problems
Re: Crio problems
I forgot to mention we are having the OTA problem and the crio is continually dropping the code.
Re: Crio problems
Can you better define what you mean by, "Dropping the code?" Also, I don't know what you're referring to by OTA, sorry.
-Danny |
Re: Crio problems
Well, does your robot accumulate a lot of static electricity? I am not sure, but I have heard that static can cause some parts of the bot to malfunction. To solve this problem, my team decided to attach an open wire from the center of the bot underneath and then let it dangle and touch the ground. I have heard certain wheels can be a primary cause of static electricity.
Re: Crio problems
Thanks all for helping a mentor came and helped us with the problem
Re: Crio problems
Can you please post how it was fixed? We are having what sounds like the same issue, and can't seem to get it fixed.
Re: Crio problems
seems like a lot of people are having a problem with their crio. mine simply wont turn on. any suggestions?
#10
Re: Crio problems
check the battery, 9/10 times, its the battery (compressors eat battery)
| cRio problems | blazingshadow | Programming | 2 | 31-01-2010 17:18 |
| cRio Problems | tanguma26 | Inventor | 3 | 25-01-2010 13:19 |
| cRio problems | tanguma26 | Programming | 4 | 21-01-2010 21:09 |
| cRio Code problems | Aaron V | FRC Control System | 2 | 14-01-2010 12:59 |
| cRIO Problems | computerboi1503 | C/C++ | 7 | 11-01-2009 09:35 |
