Go to Post Tell them your newfound passion for FIRST as a program, and let them know all you're doing is getting more involved to broaden your FIRST horizon - Dorienne [more]
Unread 19-02-2010, 17:42
infocus infocus is offline
infocus is an unknown quantity at this point
Rollers with official game piece
Has any team been able to successfully use a ball magnet with the official game piece? We have two prototype rollers built onto our robot as of now. They work perfectly fine with regular store bought soccer balls. However, as soon as we switch to the official game piece, they snag the ball and pull it under. We can't seem to get a roller that can grab the official ball well. We are using a banebots 20:1 with a fisher price. Any thoughts? We need some help.
Unread 19-02-2010, 17:51
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: Rollers with official game piece
What is the material you are using for your roller?
What surface speed are you running the rollers?
Where is your roller contacting the ball?
Is it a continuous roller with one point of contact or two or more separate rollers?
If you can find a surface with a lower coefficient of friction with the ball you might do better. Two points of contact on either side of the ball would allow a little better control also.
You might also reduce the roller speed...check out lower speeds and see what happens...
good luck
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 19-02-2010, 18:19
Our roller is a piece of PVC, but we've been wrapping it with different materials . The result is usually the same, but when we wrap it with a lower friction material, it hardly catches at all. We are running the fisher price at all different speeds with a planetary gear box, but haven't calculated the surface speed. or roller contacts the ball about 3/4 or so of the balls height. We are using a continuous roller at the moment.
We have tried lower speeds but the result remains the same.
Unread 19-02-2010, 18:31
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
1583 is usuing two of the banebot 20:1 gearboxes with FPs. For the rollers we are using banebot 3 7/8 60d (orange) wheels. We vary the speed depending on what we want to do. We have a variety of balls and it seems to work equally as well on all of them. We've found that for ball aquisition the wheels need to spin slow. To move with the ball backwards or left & right faster. We're going to a scrimage tomorrow and we'll let you know more then. Best advice is try the wheels instead of a roller.
Unread 19-02-2010, 23:06
CidTeach CidTeach is offline
Mechie
AKA: Mr. C
FRC #0334 (Tech Knights)
Team Role: Teacher
CidTeach is just really niceCidTeach is just really niceCidTeach is just really niceCidTeach is just really niceCidTeach is just really nice
Question Re: Rollers with official game piece
our team is also dealing with the sensitivity of the official game piece. Seems like the outer plastic coating is very picky and sticky. it deforms rather easy due to the deep stitching and grabs our rollers - also pvc tube.
any thoughts on a passive system to just guide the ball??
goodluck.
Unread 19-02-2010, 23:47
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
How about putting some guardrails (sort of like the cow-catcher on the front of a locomotive) in the ball magnet region of the robot. Use them to ensure the ball can't get pulled too far into/under the robot/roller.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 19-02-2010, 23:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have ours working reasonably well with the right ball.
http://www.youtube.com/watch?v=25rqm88gAXU
Received 2007 Game Piece yet? yodameister General Forum 10 24-01-2007 23:23
Game Piece Position almsfan21 General Forum 3 24-01-2007 20:11
pic: 2007 Game Piece Hint Wetzel Extra Discussion 39 07-01-2007 00:24
2006 game piece? Mike Schroeder Rumor Mill 55 08-01-2006 02:10
