Go to Post Here's my standard for-every-new-member-of-Chief-Delphi-Welcome: WELCOME TO CHIEF DELPHI!!!!!! :D - [more]
Unread 19-02-2010, 18:30
Phoenix.14's Avatar
Phoenix.14 Phoenix.14 is offline
AKA: Thomas
FRC #1757 (The Wolverines)
Rookie Year: 2007
Phoenix.14 is an unknown quantity at this point
Random Communication Loss
We have been trying to field test our robot, but we have been plagued with random communication losses. They usually occur when we try to move the robot. The driver station will lose communications and it does not reconnect unless we manually reset the robot. However, at times it will work perfectly, and other times it will disconnect as soon as we touch our joysticks. We have already done a wire check of all the jaguars and they seem to be in working order. Any ideas?
Unread 19-02-2010, 19:42
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Rookie Year: 2010
Wolfgang is an unknown quantity at this point
Re: Random Communication Loss
Well, when my team first tested out our drive train, we had many random communication loss too, only it happened more predictably. This happened either when we tried to move one of our joysticks back or when the bot managed to move a certain distance away from the driver station. I beleive our problem, and solution were actually quite simple. We just had to tighten some loose wires. I do not know if this is the cause of your problem, but I think it's worth a shot investigating.
Unread 20-02-2010, 22:33
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you're losing communication when you try to run your motors, it sounds like a power problem. Make sure you've wired your robot's wireless adapter to its dedicated 12v power connection on the Power Distribution board, and not to a regular 20A circuit breaker.
Loss of a SPAM mentor Arefin Bari General Forum 9 20-08-2007 15:58
A great Loss Wolf103FM General Forum 46 13-04-2006 00:01
Best Win-Loss Dested General Forum 15 13-03-2005 17:14
How random is random???? archiver 1999 0 23-06-2002 21:59
