team 3080 problem help
We use labview after setting up Crio and deploying code the robot still maintains no communication...no battery reading... we used the standard frc templates for programming
Re: team 3080 problem help
Do you have your slot1 Analog module plugged in, with the jumper in the correct place, and power?
Do you have your slot4 digital module plugged in, connected to the DSC, and is the DSC powered? Did you reboot after deploying code? Did you test with an Ethernet tether (no radios)? In the future, please post questions in a single forum, not multiple places. |
no it doesnt even have communication with the cord directly connected to it
No comms......
What is the IP of the cRio? Did you image it when you set it up? what is the IP of the Classmate? It should be 10.xx.yy.5, for you that should be 10.30.80.5 Did you reboot after deploying code? How are you deploying code? If you are just pressing the "Play" button, that dosen't permanently save the code, you must right-click on the FRC Robot Boot-up deployment under Build Specifications and press "Run as Startup". It might ask you to Build, so right-click on Boot-up deployment and click "Build" then when it is done go and Run As Startup. |
this is exactly what I am doing tell me if it is wrong...I format the crio with the image...then when it says successful I go to labview and build a new project after that I press build ...after it finishes building I go to main ...then press deploy when it is done...I turn off the robot start it back up and go to the driver station and try to connect but it does not work....I am using the corrent IP addresses ... can you help anyhelp is appriciated...
Here is your problem. The "Deploy" (play) button in Main dosen't actually save the code, it just places it in RAM and executes it. Thus, it will go away when you reboot. That is designed to test code, not permanently store it. In order to store it, right-click on "FRC Boot-up Deployment" under Build Specifications, and press "Run As Startup". It will deploy the code to flash, so it will stay when you reboot. If you just want to test the code, then you can go into Robot Main and press the play button, it's faster.
okay let me try it really fast and I will get to you...thanks a lot still
I followed the steps and it still didnt work...the robot doesnt even get communication...can you help....do you know anyone that can help us
| Gyro problem..HELP! | zivo123 | Programming | 13 | 14-04-2008 12:06 |
| Rookie Team 2582 with a problem... Please Help | RoboGeek99 | General Forum | 4 | 18-01-2008 00:57 |
| HELP...Wiring Problem | neslo89 | Inventor | 0 | 11-03-2006 09:16 |
