Go to Post Probably planning on milling the bumpers out of solid pool noodle stock, too. Ever wonder how they drill that hole down the middle of pool noodles? ;) - Bill_B [more]
Unread 19-02-2010, 20:34
LavaEagle LavaEagle is offline
FRC #2660
LavaEagle is an unknown quantity at this point
Limit Switch Programming Help (Have almost all of it figured out)
We have set up our robot exactly how you did this, wiring wise and then we had setup our limit switch exactly how the frcmastery.com video said to do it.
How we have our robot setup.
- a kicker is pulled back(by a victor) until limit switch is pushed
- victor then reverses until a limit switch 2 is pushed
- then waits for a button to be pushed (and the kicker is released.(this is irrelevant))
We can't get step 1 to even happen.
From everything we have looked up it looks good multiple tutorials past examples above examples.
The only thing different that we just found out is that we don't have a DIO Module set up in the programming.
At the moment programming is unable to edit the robots code?
Limit Switch Twisted eric Programming 8 22-02-2010 11:56
limit switch help program1 NI LabVIEW 10 15-02-2009 17:22
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
I've got it figured out!!! Andy Grady Rumor Mill 24 21-12-2006 19:25
gyro/accelecometer/limit switch help needed Anton Programming 4 04-02-2005 16:39
