Go to Post Leave it to CD to misconstrue a joke this badly. - connor.worley [more]
Unread 19-02-2010, 21:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Inspection Checklist posted!
The official FRC 2010 inspection checklist has been posted on the Game Manual page:
http://usfirst.org/uploadedFiles/Com...%20Rev%20A.pdf
Unread 19-02-2010, 21:54
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Inspection Checklist posted!
Please keep in mind that this is only rev A and rev B is already in the works.
That being said, I'm sure that all of the Robot Inspectors will value your constructive input.
Thanks,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 19-02-2010, 22:02
MrForbes's Avatar
AKA: Jim
I like it! The ??? for software versions is a humorous touch (although I doubt it was intended that way)
Unread 19-02-2010, 22:20
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
You mean that ??? is not the version you are running?
[Accent]
No inspection sticker for you... Two days...
[/Accent]
Mike Betts
Unread 20-02-2010, 01:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
In the same area is the new Rev J of the robot rules Section 8. Please be aware that changes to the robot rules will be enforced at events. Inspectors will use the latest version of the rules and the inspection checklist at each event. Read and compete.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-02-2010, 07:41
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
I have a question on "Intrusion of Balls Inside FRAME PERIMETER" - isn't that only a rules violation and penalty if it happens? It says under normal operation - couldn't your normal operation (by design) be to drive away from any ball headed for some area of your robot? I understand inspecting for this and flagging it to the officials, but it should not prevent the robot from failing inspection.
Close enough to taste it, too far to reach it
Unread 20-02-2010, 18:59
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Min of 12 gauge wire for 40 amp breaker?
so 14 is not ok?
Or am I reading it wrong?
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 20-02-2010, 19:08
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
so 14 is not ok?
In accordance with <R47>:
<R47> All active Power Distribution Board branch circuits shall be wired with appropriately sized wire:
A. 12 AWG (2.052mm) or larger diameter wire must be used for all circuits protected by a 40A circuit breaker.
B. 14 AWG (1.628mm) or larger diameter wire must be used for all circuits protected by a 30A circuit breaker.
C. 18 AWG (1.024mm) or larger diameter wire must be used for all circuits protected by a 20A circuit breaker.
D. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connection between the Power Distribution Board and the cRIO-FRC .
E. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connection between the Power Distribution Board and the Linksys Wireless Bridge
F. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connections between the Power Distribution Board and the Analog Breakouts and/or Solenoid Breakout if individual power feeds are used. 18 AWG or larger diameter wire must be used if a common power feed is used for multiple breakouts.
G. 24 AWG (0.5106mm) or larger diameter wire must be used for providing power to pneumatic valves.
14 AWG wire gets a 30 amp (or smaller) circuit breaker.
Mike
Mike Betts
Unread 20-02-2010, 21:31
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
so 14 is not ok?
This thread seems to suggest that the CIM motor wires are an exception:
http://www.chiefdelphi.com/forums/sh...ad.php?t=82190
Unread 20-02-2010, 22:17
AKA: Brandon Liatys
Rookie Year: 2007
Ugh. We did all the 40 amps to the jags (there all jags...) in 14.....
Unread 20-02-2010, 22:29
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Better to find out now when you have a few days to fix it, then at the competition.
Unread 20-02-2010, 22:32
AKA: Brandon Liatys
Rookie Year: 2007
We don't even have any 12.
Unread 20-02-2010, 22:47
Rookie Year: 1998
Then use 10; you got 10 feet each of red and black in the Kit of Parts.
Unread 21-02-2010, 15:27
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Gary,
Regarding the distinction between CAPABLE and NOT INTENDED TO with respect to having balls intrude by more than 3" and whether such capability (regardless of intention) is a violation of rule <R19> (see below) - this sounds like a great question for the GDC and the formal Q&A. When I read the rules and crafted the checklist task, I interpreted the rule such that simply having the ability to intrude by > 3" was a violation of <R19>.
It can get even fuzzier - I saw a few robots at Suffield Shakedown with "squishy" barriers around their robot's lower perimeter (eg rubber bands or belts). It was very easy for the robot to "hop" over a ball and trap it underneath (even though, under normal operation, the "squishy" barrier did a fine job of keep balls from being lodged under the robot). In this case, I would have been tempted to allow the robot design to pass inspection and left enforcement of the (hopefully rare) ball entrapments to the referees.
A formal Q&A thread sounds like an appropriate action to take.
Russ
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside
a) the FRAME PERIMETER below the level of the BUMPER ZONE (see Figure 8-5),
b) a MECHANISM or feature designed or used to deflect BALLS in a controlled manner that is above the level of the BUMPER ZONE.
  #15   Spotlight this post!
Unread 21-02-2010, 15:29
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Rookie Year: 2007
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
For those 4-H teams, have you used 4-H as your school name also?
Thank you,
Trying to Help
Robot Size- R11 vs. Inspection Checklist Toby314 Rules/Strategy 4 07-01-2008 10:09
Robot Inspection Checklist ChuckDickerson Technical Discussion 2 16-02-2006 21:30
Update 11 is posted, with Inspection Checklist Tristan Lall General Forum 2 15-02-2005 21:34
Inspection Checklist Draft Available Yan Wang General Forum 1 26-02-2004 20:14
Have you seen the Inspection Checklist? Matthew_H General Forum 20 23-02-2003 19:55
