Go to Post One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. - Dave Scheck [more]
Unread 19-02-2010, 23:37
Safety3rd Safety3rd is offline
FRC #3140
Safety3rd is an unknown quantity at this point
C++ Axis camera setup
I can see on the live view on the internet but thats only when the camera is conected straight to the router. how could i get the camera to send video from ethernet port 2 on the robot? and ive seen people programming the camera using java, but how would you do it in C++, cus we've been using Windriver Workbench.
Unread 20-02-2010, 10:19
Re: C++ Axis camera setup
Just in case you are looking in the wrong place, you don't actually program the camera. It is closed and runs a web server that will provide images on request.
You program using the WPI libraries. I'd start by setting up the camera using either the utility, or logging into the camera to verify it has an FRC/FRC account.
Then try to run one of the C++ example programs that uses the camera. Finally, try using the sample code.
Greg McKaskle
AXIS CAMERA HARDWARE SETUP DarKCroNo Technical Discussion 2 04-02-2010 23:35
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Help: "Setup Axis Camera" sloteera Programming 9 16-01-2010 00:59
Can't figure out the Axis camera setup... 2829ron Technical Discussion 6 20-01-2009 13:12
Setup Axis Camera - ERROR Bruno Inácio Technical Discussion 2 16-01-2009 12:37
