Go to Post Just to be clear, NOTHING anyone says here is a confirmation. The ONLY source for official answers to questions like this is the FIRST Q&A system. - dlavery [more]
Unread 20-02-2010, 11:33
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
Rookie Year: 2007
captainking is an unknown quantity at this point
2.1 screwed up our holonomic
after updating to the new 2.1 DS code, we can't run our code because it says that the polar and cartesian holonomic code is not recognized by the libraries, what do we do?
Unread 20-02-2010, 11:36
Re: 2.1 screwed up our holonomic
I believe 2.1 added some capability to the holonomic drive VI and made it match the documentation. Press the run button and it will help describe the errors. Post more specific questions if you need help with fixing it.
Greg McKaskle
Unread 20-02-2010, 11:59
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
You guys at NI are doing a great job, and we thank you.
However, mandatory updates to LabVIEW this late in the build cycle should not break existing user code, even if the changes are to add functionality or make the code match the documentation. The only exception would be a safety issue.
In the specific case of the holonomic VI, the old VI should have been left alone, and a new VI, with a different name, should have been created. The old VI could be deleted after giving a month's notice to teams.
Just my 2 cents.
Unread 20-02-2010, 19:56
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
We try not to make changes late in the game that will affect your code. In theory, the holonomic change should not have affected you. We made the holonomic VI polymorphic (can now choose a specific VI to better meet your needs). However, the default instance of the polymorphic VI is the same as the original before the update. Could it possibly be that you edited the original? That could have caused this problem.
Unread 21-02-2010, 11:16
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
I was afraid that the update would mess us up too but it didn't I posted our code in a post a while ago if you want to go look at it.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
OK, Humanity's screwed when they turn on the Large Hadron Collider Michael Hill Chit-Chat 6 10-09-2008 16:59
Q&A Forum Screwed Up? Petey General Forum 2 10-01-2006 19:16
Holonomic... Greg Perkins Technical Discussion 2 02-02-2005 11:59
Screwed up results? TheFork 3D Animation and Competition 18 18-05-2002 15:47
Time Screwed Up Matt Leese CD Forum Support 0 21-06-2001 21:53
