Go to Post This thread has officially jumped the shark! the old guy shark :) - IndySam [more]
Unread 20-02-2010, 11:59
executionR executionR is offline
FRC #3080 (So-called Robotics)
Team Role: Student
executionR is an unknown quantity at this point
team 3080 problem no robot communication
Anyone help the problem is that after installing the crio and deploying the code the robot has no communication...I do not believe that the problem is the way we install the image on the crio or the deployment process, but that after doing that there is no communication between the classmate and robot... we used the labview templates for deployment....... can anyone help
Unread 20-02-2010, 23:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: team 3080 problem no robot communication
Did you go through the bench tests described in the control system manual? Have you installed the latest updates to the software development and Driver Station code? What does the Diagnostic tab on the Driver Station tell you?
team 3080 problem help executionR Programming 8 20-02-2010 23:05
Joystick Communication Problem mechatronics NI LabVIEW 4 03-02-2010 20:25
Drive Station Communication Problem CHSboy Control System 0 18-02-2009 18:22
