Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 20-02-2010, 12:35
dancola1 dancola1 is offline
dancola1 is an unknown quantity at this point
Need help with Adding VIs
So we have made most of our robot spcific VIs and can't get into our main project and have them work. We have out them in robot main and can't figure out anything else to make it work. Please help us, we need to fix this asap so that we can have some practice with our robot.
Thanks for your help in advance.
Dancola1
Team 2170
Unread 20-02-2010, 16:49
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Re: Need help with Adding VIs
Where have you added them in the project?
In the Project Explorer window, make sure your VI's you have created are in the 'RT CompactRIO Target' area of the project and not under 'My Computer'
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 21-02-2010, 14:31
no, we are having problems incorporating the VI. We wrote our code and now whenever we use our robot only the drive works but none of the VIs that we wrote.
Adding Inputs or Outputs to existsing VIs paulcd2000 NI LabVIEW 7 12-01-2009 22:39
I Need Help With An Arm Team ICE #1611 General Forum 4 20-01-2005 14:37
need help with programming magical hands Programming 1 11-02-2004 22:12
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Need help with C++ Tton Programming 7 04-11-2003 19:15
