Go to Post Hey that was easy, we settled the argument on CD in one post! :^) - KenWittlief [more]
Unread 20-02-2010, 12:45
executionR executionR is offline
FRC #3080 (So-called Robotics)
Team Role: Student
executionR is an unknown quantity at this point
no stop button
the robot maintains code and communication but the joystick..stop button...etc do not register on the computer...but they are plugged in..and have power.. anyhelp
Unread 20-02-2010, 23:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: no stop button
Try plugging the Stop button into one side of the Classmate and one of your joysticks into the other side. If they work that way, your USB hub is probably broken. (Either that, or you don't have its black connector plugged in properly.)
TeleOp Init/Stop vs. Auton-Iterative Init/Stop Ziaholic NI LabVIEW 11 07-02-2010 22:19
Attention tipped over robots! Please use the e-stop button. sanddrag Rules/Strategy 23 14-03-2006 14:38
Emergency Stop Button Required? TangoBravo1318 Technical Discussion 13 02-03-2003 19:06
Can a student Coach press the Stop Button archiver 2001 3 24-06-2002 02:39
