Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 02-20-2010, 02:37 PM
brianelite brianelite is offline
FRC #2898
brianelite has a spectacular aura aboutbrianelite has a spectacular aura aboutbrianelite has a spectacular aura about
Holonomic Drive with one joystick
Has anyone here implemented Holonomic Drive with one Joystick here?
We tried HolonomicDrive(stick->GetMagnitude(),stick->GetDirectionRadians(), 0);
(also with degrees)
and didn't get a drivable robot... inverting the motors didn't help either...
We eventually got an Arcade Drive equivalent using the holonomic drive function with:
HolonomicDrive(-stick->GetGetX(),0, stick->GetGetY());
How are you implementing the Holonomic Drive with one joystick? Help is very appreciated!
Unread 02-20-2010, 04:55 PM
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: Holonomic Drive with one joystick
3 axis joy stick (ie side to side, front to back, and twist). if u dont have a 3 axis joystick then u cannot use only one joystick. you must use two joysticks and have one of the axes on the second be twist.
3 axis joystick: http://www.logitech.com/index.cfm/ga...s/291&cl=us,en
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 02-20-2010, 07:41 PM
FRC #2898
we have that joystiq: can you please give us the line of code to make that joystick work with holonomicdrive?
Unread 02-22-2010, 06:07 PM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
HolonomicDrive(joystick->GetMagnitude(), joystick->GetDirectionRadians(), joystick->GetZ());
Be careful on the GetZ parameter to make sure that's the correct axis you want for the "twist". On my Microsoft SideWinder joystick, the "Twist" is Z. It may be different on your joystick.
trouble with the holonomic drive ronlv NI LabVIEW 2 02-10-2010 08:29 PM
Using holonomic Drive with Dual Joystick Controller robotic321 NI LabVIEW 2 02-05-2010 11:45 PM
Holonomic drive vi with mecanum wheels dwodrich NI LabVIEW 7 01-18-2010 04:01 PM
One Joystick Drive mattsavela Programming 20 05-19-2005 09:28 PM
question about one joystick drive programing james700 Programming 13 01-29-2003 02:49 PM
