Installing LabVIEW - Activiation Code?
I understand it's pretty late in the build season, but our team has been programming in Java. I wanted to install LabVIEW just to test some things out, but I could not find the installation key that it requires.
I am currently running a trial version. Does anyone know where the installation key is located (I haven't found it on the "FIRST Competition Software" packet with the DVDs)? |
Re: Installing LabVIEW - Activiation Code?
The activation code should be on the sleeve that holds the installations CDs. In a pinch you can use this activation code L13R02010 - it's the one I set up for the beta.
However, you should eventually find your official code in case we need to turn off the beta code. |
The official code for all teams is L13R00000. It was sent out in an email for our team, I forget if I got it from FIRST though... Meh.
i had to use two separate codes to put in. one for the regular laptop we use and one for the classmate. the one for the laptop was included and was with the packet of programming stuff and the other one was the one that we had to use on the classmate was posted right before me.
| error installing labview error 1335 | jerometab | NI LabVIEW | 0 | 06-02-2010 18:17 |
| Problem installing Labview on VISTA | windell747 | NI LabVIEW | 1 | 01-02-2009 22:55 |
| Have You Had Problems installing LabVIEW 8.0 Student Edition? | Danny Diaz | National Instruments LabVIEW and Data Acquisition | 1 | 11-03-2006 08:44 |
| Problem installing Labview | Joohoo | LabView and Data Acquisition | 3 | 08-01-2006 10:51 |
