Go to Post I have many ideas, every last one of them involves finding something more productive to do with your time. - Andrew Schreiber [more]
Unread 02-20-2010, 04:36 PM
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
solenoid problems
I need help with Programming the solenoid to a the trigger button on our controller it will be on the kicker joystick.
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Jaguar;
public class Demonized extends SimpleRobot {
    private static final long TIME_DELAY = 1000; // in milliseconds
    RobotDrive drive = new RobotDrive(1, 2);
    Joystick leftStick = new Joystick(1);
    Joystick rightStick = new Joystick(2);
    Joystick kicker = new Joystick(3);
    Watchdog fenrir = Watchdog.getInstance();
    Compressor fluffy = new Compressor(1, 1);
    Joystick leftstick = new Joystick(1);
    Joystick rightstick = new Joystick(2);
    Jaguar spot = new Jaguar(4);
    Joystick pup = new Joystick(4);
    void setUpRobot() {
        fluffy.start();
        fenrir.feed();
    public void autonomous() {
        setUpRobot();
            while (true && isAutonomous() && isEnabled()) {
                for (int i = 0; i < 4; i++) {
                    fenrir.feed();
                    drive.drive(0.5, 0.0);  // drive 50% fwd 0% turn
                    fenrir.feed();
                    drive.drive(0.0, 0.5);  // drive 0% fwd 50% turn
                    fenrir.feed();
                    drive.drive(0.0, -0.5); // drive 0% fwd -50% turn
            drive.drive(0.0, 0.0); // drive 0% fwd, 0% turn
    public void operatorControl() {
        setUpRobot();
        while (true && isOperatorControl() && isEnabled()) // loop until change
            drive.tankDrive(leftStick, rightStick);
            Timer.delay(0.005);
            fenrir.feed();
           // New compressor code...
if (fluffy.getPressureSwitchValue()) {
fluffy.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOff);
} else {
fluffy.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOn);
    //And don't forget to turn the compressor off when exiting your operatorControl loop...
help will be much appreciated.
Unread 02-20-2010, 05:15 PM
ygd ygd is offline
FRC #3341 (Manhattan Project)
Rookie Year: 2010
ygd is an unknown quantity at this point
Re: solenoid problems
What's the point of this:
Code:
} else {
Also, this was our code when we were using pneumatics for our kicker:
Code:
if (System.currentTimeMillis() - lastFired >= 2000) {
                if (j.getTrigger() && !fired) {
                    fire();
                    fired = true;
                    lastFired = System.currentTimeMillis();
                } else if (!j.getTrigger() && fired) {
                    fired = false;
            try {
                Thread.sleep(50);
            } catch (Exception e) {
                System.out.print(e.getMessage());
                e.printStackTrace();
Where fire() launches the solenoids and fired is a boolean set to false and lastFired is a long set to 0. This code also makes sure you can only fire once every two seconds.
Unread 02-20-2010, 05:18 PM
FRC #0581
} else {
this will i believe to turn off the compressor
(have not yet tried it yet)
also is the only import we need is
import edu.wpi.first.wpilibj.solenoid;
right
thanks.
Unread 02-20-2010, 05:25 PM
FRC #0581
How can I implement that into my code.
Unread 02-20-2010, 05:58 PM
nikRbokRz nikRbokRz is offline
FRC #1683
nikRbokRz is an unknown quantity at this point
} else {
right
thanks.
First of all, instead of doing "edu.wpi.first.wpilibj.Relay.value.kOn", isn't it much easier to just to "Relay.value.kOn"?
From what my team assumed, the compressor automatically turns on/off, depending on the pressure switch. We initially couldn't get it to work, but it turned out to just be a bad spike. So I'm not really sure if you need to be turning it on/off.
As for the solenoid, yes all you need to import is
Code:
import edu.wpi.first.spilibj.Solenoid;
Depending on how you've connected your solenoid(s), you will have to set them true or false to get it to work as you wish.
Hope that helped.
Unread 02-20-2010, 10:34 PM
KayyPii's Avatar
KayyPii KayyPii is offline
FRC #1404 (SHOCKs)
Rookie Year: 2007
KayyPii will become famous soon enough
After you import the solenoid class, you will have to create your solenoid objects in Java. You can do this using :
Solenoid kicker = new Solenoid ( slot, channel );
then in your program, you can check the status of the trigger using an "if" selection and use the set( boolean on ); method to turn the solenoid on.
=>"That hole you drilled is a little off."
=>"Don't panic, just make it bigger and put a washer on it!"
=>Eye ball once, and cut as many times as it takes
Unread 02-21-2010, 02:14 PM
FRC #0581
Can you please show me an example this is my first year programming in Java and I have no mentor to help.
Unread 02-21-2010, 10:08 PM
KayyPii's Avatar
FRC #1404 (SHOCKs)
Rookie Year: 2007
Code:
Solenoid kicker = new Solenoid ( 7, 1 ); //locate a solenoid on slot 7 of cRio and channel 1 on the solenoid breakout.
if ( pup.getButton( Joystick.ButtonType.kTrigger ) == true ) //if the switch is pressed
         kicker.set(true); //turn on the solenoid
else
         kicker.set(false); //turn off the solenoid
That is pretty much our code for our kicker with the few changes to the variable names. Also, I believe that when you initialize the solenoid to channel 1, it is the first channel on the breakout board. I think its labelled as 0. Hope this helps
Solenoid actuation problems Alexandstein Pneumatics 4 02-17-2010 09:39 PM
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 01-30-2010 05:46 PM
single solenoid seanl Pneumatics 4 02-18-2007 02:32 AM
Programming a Solenoid Brigander Pneumatics 4 02-17-2007 02:06 PM
Labview problems and code problems ajsetter Programming 25 01-18-2006 05:07 PM
