Missing driver station library files
We installed the two recent updates to the driver station and to LabVeiw but when we try to build our code it says we cant find the following driver station library files:
Set user data.vi Updatedashboard.vi Dashboard.vi Builddashboardpacket.vi Set driver station status.vi If anyone could help us with finding these files or fixing this problem it would be greatly appreciated. |
Re: Missing driver station library files
Can you post more details - maybe the exact error text. What exactly are you trying to build? If it is the robot code, I'm not clear why it's looking for the dashboard VI.
Were you building successfully before the update? Can you build the default robot project? |
You installed the LabView update as well, right?
Yes we did install the update, however, when building the code, it tells us to locate those files manually, as in when going through the code a file window pops up looking for those files.
| Driver Station Missing 'nicyapi.dll' Issue. | Twisted eric | Programming | 4 | 14-02-2010 21:14 |
| Driver Station Missing Pieces? | furiousgeorge | Control System | 1 | 28-01-2010 19:28 |
| Driver station missing VIs | aeasson | FRC Control System | 6 | 11-01-2010 21:00 |
| 2010 Driver Station Netbook Driver Account and Java | joshholat | FRC Control System | 2 | 10-01-2010 15:04 |
| Labview Missing Library | bixbyrobotics1 | NI LabVIEW | 2 | 15-02-2009 17:38 |
