Go to Post I didn't know that Dean Kamen had 3 arms. - kevin.li.rit [more]
Unread 23-02-2010, 10:22
rath358's Avatar
rath358 rath358 is offline
AKA: max
FRC #0093 (NEW Apple Corps)
rath358 is on a distinguished road
Re: vision causes mega-lag in main loop
here is a screenshot of the error that comes up
Unread 23-02-2010, 12:44
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That's not an error. It's just an informational message telling you that there's already code running on the cRIO, and that it will be halted in order to run the code you're telling it to run instead.
Unread 23-02-2010, 16:03
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
I downloaded and tested your Camera Lag Troubleshoot.zip code. With vision enabled I get loop times between 40 and 170 ms. With vision disabled I get loops times between 30 and 65 ms.
Then I turned off auto error logging following the instructions here. With vision enabled I now get loop times between 15 and 65 ms. With vision disabled I get loop times between 15 and 23 ms.
You might want to try turning off auto error logging.
Unread 23-02-2010, 19:45
Sorry for the delayed post. I answered earlier today, but got a message a moderator would have to review my post. Now I see my post never made it.
I tested your attached Camera Lag Troubleshoot.zip code. I was able to improve the loop timing by turning off automatic error logging on the robot. To do that look for my post titled
"Turning off automatic error logging in LabVIEW may improve loop timing "
I'd give you the link, but I suspect that's what caused problems earlier.
Hope this helps.
Unread 24-02-2010, 22:06
rath358's Avatar
AKA: max
Thank you very, very much for this. I will not be able to test it until tomorrow night, but it sounds like exactly the kind of thing I am looking for.
now, back to that homework backlog...
2010 FRC camera vision tracking delay, image processing lag pspeer C/C++ 18 18-02-2010 07:24
Main loop wierd problem Tottanka Programming 5 10-02-2008 15:14
Mega FIRST How-to Book Leon Machado IV General Forum 14 20-05-2005 20:21
Rewriting main loop Max Lobovsky Programming 4 04-01-2005 18:35
