Go to Post wow Paul and Rich in a photograph, i thought that if that much nerd got together that a black hole would form - Mike Schroeder [more]
Unread 21-02-2010, 08:47
Chris is me's Avatar
AKA: Pinecone
Re: What did we learn - FIRST Scrimmages?
We found out that if you want to play at a scrimmage, you need to build your robot faster, plan it out better, and not mount your battery in a manner that causes your electrical board to fail when you fly up a bump.
While technically not at a scrimmage, but just on a field, we also figured out the tunnel is not a terrible zone transfer method, but it's very vulnerable to defense like bump climbing is.
Unread 21-02-2010, 09:17
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
I learned that our team overestimated the necessary drivetrain to get over the bump. We made an articulating drive with 6 wheels, 16 sprockets, and 27 feet of chain, and we were going over the bump easily....but so were all of the other teams at Shakedown. Teams with the kitbot frame and 4 mecanum wheels were going over without too much trouble at all. 230, which was arguably the best robot there, had that exact setup.
However, I also learned that having 6 sticky wheels did NOT hamper our ability to turn, and it helped a whole lot in being able to push around other bots. It was literally like a warm knife through butter. Also, in learning things about our robot, we are then able to assess what we can and cannot do, and where we can and cannot play the best on the field. As it is, our kicker will be great picking up balls that were launched from the far zone, and just popping them quickly into our goals.
(09-12) - FRC 176 - Aces High
(13 - 14) - FRC 229 - Division By Zero
Clarkson University - 2016, Innovation and Entrepreneurship
Unread 21-02-2010, 10:47
SilentHAWK6's Avatar
SilentHAWK6 SilentHAWK6 is offline
FRC #0061 (Shifters)
Team Role: Human Player
SilentHAWK6 is an unknown quantity at this point
Where any of the cast saved/recorded?
Unread 21-02-2010, 11:11
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Rookie Year: 2007
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
We found that the ability to move between zones consistently and quickly can be the key for a successful match, that controlling a majority of the balls on the field doesn't always lead to high scores (not that it hurts your chances), and once again the drivetrain of the robot is the most important design feature; being able to go where you want in a quick and efficient manner will once again play a huge role.
Unread 21-02-2010, 11:16
Nickel5 Nickel5 is offline
FRC #2472
Nickel5 is an unknown quantity at this point
I found:
Not much travel over the bumps
  • Seemed to be more beneficial to the other alliance than to your own due to open field section.
Low scoring
  • High score was 6, a more average score was 2
Hard to push a ball over the bump
  • Just ended up being caught under the frame.
Once a ball is up against the alliance station walls, it's dead. If it's against the side walls in the middle section, it's also dead.
Autonomous is very important because it's a unimpeded chance to score
Hard to manipulate ball, even with ball control
Unread 21-02-2010, 11:30
sportman3333333 sportman3333333 is offline
FRC #0999 (CRASH)
Rookie Year: 2007
sportman3333333 has a spectacular aura aboutsportman3333333 has a spectacular aura about
Did anyone manage to find the e-stop button at the driver stations at Suffield Shakedown. Team 999 has lost the stop button. If anyone has it, please pm me.
Thanks
Unread 21-02-2010, 13:00
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
I learned how important ball possession is and how not-so-important bump climbing is. We would climb the bump max once per match and still be shooting balls all match. Teams that lacked ball possessors were
A) Having trouble lining up kicks and
B) Taking lots of pictures of our front roller
We also learned the importance of lining up quickly, and you can miss to the wall slightly and still make a bounce shot.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 21-02-2010, 14:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I learned how many teams did not realize how important ball possession is.
Unread 21-02-2010, 18:45
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Jim,
TOTALLY agree with you.
This is why we are still scrambling wondering if we should powdercoat or not tonight or tomorrow, with less programming and driver practice.
We spent 1 1/2 weeks trying to find the right speed, motor, device, frame stop, etc. that we felt was to our satisfaction on possessing the ball.
Its not perfect, but with driver practice in how they turn and do reverse turns, it certainly improves.
One of the schools here had a scrimmage, and that was the biggest problem.........good ball possessing.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 21-02-2010, 18:56
MrForbes's Avatar
AKA: Jim
Our robot frame is rusty steel....oh well...at least it can hold onto the ball reasonably well.
Unread 21-02-2010, 21:09
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
no team (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
It is very surprising that many teams did not think of this. We also overlooked the importance of ball manipulation. With the past few games being like they were, it is surprising that many teams overlooked this thing of extreme importance. Each game relies on manipulation of the game pieces. For some reason people think that other aspects are more important, but when you think about it, if you can't posses the ball and aim it, you cannot win easily at all. We figured that out a little too late.
Unread 21-02-2010, 18:47
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
thanks for confirming what we were afraid of.
With bumpers on and being high off the ground, how the heck do you get it from the wall, without a manipulator that wacks it back into play?
I've seen videos of vacuum suction cups that work well, once it grabs the ball. But without rollers, it would make it almost impossible. Those videos showed it with their bumper off.
Kind of reminds me of 2008, comparing teams that had the top rollers vs. those that did not. We didnt unfortunately.
Unread 22-02-2010, 02:42
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
A robot that has the ability to strafe (swerve, mecanum) can acquire balls with vacuums sans rollers if it strafes diagonally into them.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 22-02-2010, 04:28
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Are there any videos from any of these scrimmages? I (and I am sure others as well) would love to see them.
p.s. - Please take permission from the teams if you are going to post a video of their robot.
  #15   Spotlight this post!
Unread 22-02-2010, 04:46
Check out this thread: http://www.chiefdelphi.com/forums/sh...threadid=83332
Just a few links provided by squirrel so far...
What did everyone learn from this weekend's scrimmages? Mr MOE General Forum 50 21-02-2009 10:02
So, what did we all learn from the scrimmages and play dates today? Mr MOE General Forum 20 17-02-2008 11:23
What did you learn in todays scrimmages? JohnBoucher Off-Season Events 17 21-02-2005 00:28
