Go to Post What Delphi says doesn't matter. What the official Q&A says matters. - Tetraman [more]
Unread 20-02-2010, 21:04
TUBZ TUBZ is offline
FRC #1622
TUBZ is an unknown quantity at this point
Exclamation Limit switch not working properly.
We want to use two limit switches to control a motor in forward and in reverse.
The limit switches are actuating on all channels of the digital sidecar, it does not matter which port we plug it into. We want the switch to stop the individual motors from running. We have tried both constructors (channel only, as well as slot and channel) with the same results. Our code is:
Code:
DigitalInput *limitSwitchReverse;
DigitalInput *limitSwitchForward;
// Ctr using only channel
limitSwitchReverse = new DigitalInput(13);
limitSwitchForward = new DigitalInput(14);
// Alternative: Ctr using slot and channel
//limitSwitchReverse = new DigitalInput(4, 13);
//limitSwitchForward = new DigitalInput(4, 14);
if (btn1)
	if(limitSwitchReverse->Get() == 0)
		device->Set(Relay::kOff);
	else
		device->Set(Relay::kReverse);
else if (btn2)
	if(limitSwitchForward->Get() == 0)
	else
		device->Set(Relay::kForward);
else
could someone please post a sample code which demonstrates the correct way to use a limit switch connected to the Digital I/O, to interrupt a spike connected to the Relay.
Thanks
SHIZAMLES!!!
Unread 20-02-2010, 21:11
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
Team Role: Leadership
Rookie Year: 2007
whatabouteve is an unknown quantity at this point
Re: Limit switch not working properly.
class RobotDemo : public SimpleRobot
DigitalInput *switch1;
public:
RobotDemo(void):
switch1 = new DigitalInput(4,2);//4 is the modual in cRio and 2 the input port
that is initializing it but you need to do the rest. you will get a 1 or 0 and need to declare a bool variable to take the number from it in the form
variable = switch1->Get();
or
use switch1->Get() in your conditional
hope it helps
Unread 20-02-2010, 21:24
FRC #1622
1) we tried what you said, even though the logic wasn't any different than our original, and we still had the same results.
2) we also found that when we actuate the limit switch, it not only blocks all relays but also all the PWM outs.
SHIZAMLES!!!
Unread 20-02-2010, 21:48
AKA: Dean Keithly
Rookie Year: 2007
2 quick things you have things in the code posted that are not declared and things. if you posted the whole thing then i might be able to help better. sometimes there are just miniscule errors that someone else can see but you can't.
for the second thing how do you get the code to go into that grey box thing
Unread 20-02-2010, 22:32
FRC #1622
grey box thing? CRio?
SHIZAMLES!!!
Unread 20-02-2010, 22:43
AKA: Dean Keithly
Rookie Year: 2007
no i mean on the forum where it says code and has the grey box of code
code:
(grey box with code)
Unread 20-02-2010, 23:01
FRC #1622
oh, haha sry. well we figured out was was wrong, we had some crossed wires.. but thank you for your help
SHIZAMLES!!!
Unread 20-02-2010, 23:03
AKA: Dean Keithly
Rookie Year: 2007
good luck
Code not loading properly Al3+ C/C++ 19 31-01-2010 01:11
Laptop is not finding the cRIO properly? Studentish Electrical 4 07-05-2009 12:03
1 joystick controls not turning properly andrew_4_life Programming 4 28-03-2008 01:22
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
PLEASE HELP: OI switch box not working RbtGal1351 Control System 2 18-02-2006 19:34
