Go to Post There is a big difference between "we have not been able to figure out how to do it." and "it's impossible" or "don't even bother." Let's be constructive not discouraging. - PVCMike [more]
Unread 20-02-2010, 22:27
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
pic: A close up of the Jaguar
Unread 20-02-2010, 22:29
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: pic: A close up of the Jaguar
Just a quick question, but should you really cover the fan on the speed controller with tape? I don't know if its temporary, but i think that that could cause a problem.
Unread 20-02-2010, 22:49
The tape will be removed before operation. It's a best practice to protect sensitive electronics, like the Jaguars, from metal shavings when you're working on the robot. Since we're still adding a few parts, doing some drilling and cutting, we didn't want to risk a shaving shorting something inside and burning them out.
Unread 22-02-2010, 00:20
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
I think this violates the rule concerning wiring PWM and CAN at the same time. I believe it must be one or the other.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 22-02-2010, 01:34
There are no wires going into the PWM port.
pic: Jaguar... Under the Hood MasonMM Extra Discussion 14 09-08-2008 22:03
Mounting GTS - how close is close? emmell Electrical 7 15-02-2008 00:35
when do the nominations close king_moleman Unsung FIRST Heroes 1 26-04-2004 15:27
So close, but not close enough archiver 2001 1 23-06-2002 23:45
After the parks close... Amy Beth Championship Event 23 16-04-2002 09:44
