Go to Post I can neither confirm nor deny that I've worked on alot of pretty cool stuff. - Gary Dillard [more]
Unread 21-02-2010, 03:16
Labot2001's Avatar
Labot2001 Labot2001 is offline
FRC #3332
Labot2001 is an unknown quantity at this point
How to attach Servos to Brackets?
Can't find the manuals for our servo brackets (are there any??), no luck online either. We're wondering how to mount the servos to the brackets basically, because we can't made head or tail of these brackets...
Any help would be mucho appreciano, thanks
Unread 21-02-2010, 03:18
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: How to attach Servos to Brackets?
Got any pictures of the brackets?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 21-02-2010, 03:19
MWB's Avatar
MWB MWB is offline
Building and building.
AKA: Marcus W. Byrd
FRC #3716 (WABots)
Team Role: Mechanical
MWB is just really niceMWB is just really niceMWB is just really niceMWB is just really nice
Send a message via AIM to MWB
What you are looking for is called a servo horn, this is what they look like.
Marcus W. Byrd
Team 3716
Lead CAD/Design and Fabrication.
Unread 21-02-2010, 03:21
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
There are servo brackets and servo horns. They are different. I don't know which they're looking for, and I don't think you do either.
Past teams:
Unread 21-02-2010, 03:23
MWB's Avatar
MWB MWB is offline
AKA: Marcus W. Byrd
FRC #3716 (WABots)
he asked how to mount the servos to the brackets, which means he is looking for a horn
Marcus W. Byrd
Team 3716
Unread 21-02-2010, 03:24
MWB's Avatar
MWB MWB is offline
AKA: Marcus W. Byrd
FRC #3716 (WABots)
or he could be asking which way the brackets go
Marcus W. Byrd
Team 3716
Unread 21-02-2010, 03:25
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
No, it doesn't. I pulled a servo bracket out of an R/C plane a couple months ago, and it looks nothing like a servo horn. I'd post a picture, but I don't happen to have one.
A servo mounting bracket != a servo control arm/control horn.
Past teams:
Unread 21-02-2010, 03:31
MWB's Avatar
MWB MWB is offline
AKA: Marcus W. Byrd
FRC #3716 (WABots)
i think we are disagreeing over something that doesnt matter, lets wait for his reply. he asked how to mount the servo to a bracket, this can either be for the actual moving part of the servo or how to mount the casing of the servo
Marcus W. Byrd
Team 3716
Unread 21-02-2010, 03:36
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
It does matter. They are two different parts, with two completely different functions.
If you can locate a 2005-2006 camera housing, look at the servo brackets that are built-in. Now look at the servo arms. They are not the same, and calling the arm a bracket will confuse everyone.
And many days did pass, and many times did the moon wax and wane, and the tower was still not yet builded. So I, Abibarshim, did corner the Chief Scribe and ask him, "What goeth on here?"
The Chief Scribe fell to his knees and said: "O Great and Merciful King, the Makers of Engines give us scrolls of materials for to purchase. But, verily, no man knoweth what the scrolls signify, save the Makers of Engines themselves. For they call not a spade a spade, but call it here a delver and there a digger and another place an entrenching tool and yet another a geovolvometer, so that the scroll of material agreeth not with the design papyrus. And strange to behold is their numerology."
I. Once thou decidest what name to call a thing, that shall be its name forever after, until eternity passeth. Nor shall thou call any other thing by that name, for each thing shall have a name unto itself.
From http://www.sacbusiness.org/cs/hester...Abibarshim.htm
Past teams:
Unread 21-02-2010, 03:39
MWB's Avatar
MWB MWB is offline
AKA: Marcus W. Byrd
FRC #3716 (WABots)
we are not even sure if he is talking about the camera housing
Marcus W. Byrd
Team 3716
Unread 21-02-2010, 03:40
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
I know for a fact that he isn't. It's not available any more (phased out around 2007/2008). It is a part that has a servo bracket integrated into it, and I was thinking that it might help make a point.
Past teams:
Unread 21-02-2010, 16:40
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
As long as you can mount the servo securely, you don't need to worry about the bracket.
BTW: These are servo brackets.
Unread 21-02-2010, 16:44
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
They're also overkill. For those, you'd slap the servo in so that the mounting tabs on the servo are lined up on the two small tabs, and then put your screws in.
All you really need is a flat piece of material with a hole that the servo body can fit into and 4 screws or small bolts.
Past teams:
How to attach wire to motors? jgraber Motors 11 22-01-2009 16:58
How do you attach a pulley to extruded aluminum? Erich & Posse Technical Discussion 5 19-01-2008 15:34
How do i attach pictures? Captain Thunder CD Forum Support 1 22-06-2007 16:56
how to attach a carrier plate for a turret arm to the robot. vivek16 Technical Discussion 11 18-04-2007 11:16
How do you attach a wheel to a shaft? SilverStar Technical Discussion 21 21-01-2003 19:52
