Go to Post - Only think of Gracious Professionalism as a standard to work toward personally. - Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 02-21-2010, 12:14 PM
scorpions980 scorpions980 is offline
FRC #3017
scorpions980 is an unknown quantity at this point
problem with programming solenoid vales
our team is currently using the pneumatic system for the arm and we are having problems with the double solenoid valve. the module is connected to slot 8. and the sides are connected to the first and second channel. the compressor is operated by a external battery and there are 4 cylinders connected in a chain which is connected by surgical tubing to the pneumatics which is connected by tubing to the piston. i dont see a problem with the wiring because the lights on the solenoid alternate when i press the button i set it to. and it works manually with the blue button on the solenoid. the code is very simple as well
Solenoid * compress;
Solenoid * decompress;
//its initialized inside the default robot
compress = new Solenoid (1);
decompress = new Solenoid (2);
//inside is operator loop
if (leftstick->GetRawButton(6)){
compress->Set(true);
decompress->Set(false);}
else{
decompress->Set(true);}
can someone tell me a way to make the piston fire and not just make the lights on the solenoid switch on and off? thank you.
i am sure everything is connected corrected and yes it was enabled there was nothing that we could tell was wrong
Unread 02-21-2010, 12:56 PM
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: problem with programming solenoid vales
Is the soleniod breakout connected to the 24v connector on the PDB (same connector as the cRio), or is it connected to another Wago terminal on the PDB?
It should be connected to the former, as the rest of the PDB only provides 12v but the solenoids require 24v.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 02-21-2010, 05:37 PM
FRC #3017
oh wow, i cant believe i missed something so obvious, thanks a bunch
$@#$@#$@#$@# freshmen musta wired it when i wasn't paying attention.
Unread 02-27-2010, 10:13 AM
willzone1's Avatar
willzone1 willzone1 is offline
FRC #0246 (Overclocked)
Team Role: Electrical
willzone1 is an unknown quantity at this point
Actually, according to the manual the solenoid breakout board accepts 6-30V. There is no need for 24V, 12V does fine. We have had ours hooked up through a 12V Wago terminal on the PDB, and we have had our solenoids working great.
Unread 02-27-2010, 10:50 AM
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
That's because you are using 12VDC solenoids.
The one solenoid that came in the 2010 KOP is 24VDC.
You have to wire the voltage that fits your solenoids. They are labeled.
Limit switch to solenoid problem TPekarjr Electrical 4 01-28-2010 08:17 PM
solenoid programming holty531 Programming 0 02-10-2008 04:17 PM
problem connecting the solenoid arpitshah Pneumatics 1 01-21-2008 08:47 AM
Programming a Solenoid Brigander Pneumatics 4 02-17-2007 02:06 PM
Solenoid Programming duckshepherd Pneumatics 1 02-17-2003 09:15 AM
