LEDs on the Cypress PSoC
if anyone else is trying to use the cypress PSoc... we found out the hard way that you need to have the driver station IO in advanced mode. otherwise that functionality remains disabled.
to change it, on the driver station goto IO > configure > select enhanced hope that helps anyone else who needs it |
Re: LEDs on the Cypress PSoC
You should be able to use it in compatibility mode too. You use the simpler API from last year, and it autoconfigures to 8 in and 8 out. I duplicates the outs to the LEDs, and you only get 4 analog inputs.
Greg McKaskle |
I posted a few days ago about this, so I'm glad someone's tried it. We've been using the compatibility mode so far and it hasn't worked at all, but when our electrical guy gets here and they let me have the robot for a few minutes I'll tell you if there are any results.
My question is, does the dashboard save the enhanced setting, or do you have to change it every time you turn on the Classmate? |
The dashboard saves many settings including the I/O settings. It will load and use them the next time it is run.
Greg McKaskle |
Mkay, good. As it turns out when we tested the cypress on another computer it responded fine, but it does not do so on our classmate. We're currently formatting it.
| Programming the Cypress Board | NinjaSpawn94 | C/C++ | 1 | 20-02-2010 15:08 |
| Programming the Psoc | railerobotics | Technical Discussion | 5 | 18-02-2010 10:10 |
| Wiring Switches to the PSoC board | Raj1977 | Electrical | 13 | 07-02-2010 23:24 |
| Programming the PSoC | PortugazD.Ace | Programming | 19 | 31-01-2010 13:14 |
| Cypress PSoc Programmer Port Selection problem | Steven_585 | FRC Control System | 2 | 23-01-2010 23:06 |
