Go to Post Band geek FIRST geeks = uberparty! - Nuttyman54 [more]
Unread 21-02-2010, 14:54
Kyledoo Kyledoo is offline
FRC #2603
Kyledoo is an unknown quantity at this point
Using DashboardDataSender
I want to use the dashboarddatasender class to send info such as the gyro and other vision data to the dashboard. How is this done? right now I can change values in the DashboardDataFormat.cpp file and they are reflected in the sent data. I tried declaring DashboardDataSender data; and initializing it, but it gives an error DashboardDataSender does not name a type. I see that by using DashboardDataSender, I can pass in values for the gyro, joystick, and other things, which is what I want to do.
Using Encoders svenw C/C++ 2 14-01-2010 16:43
Using the IR feliks_rosenber Sensors 20 13-02-2008 09:31
Using gyro.h Douglas Rohrer General Forum 0 03-02-2008 15:59
Using Reactor... Ryan Dognaux 3D Animation and Competition 19 22-05-2004 23:10
Using Sensors thoughtful Programming 11 16-12-2003 10:28
