I am a programmer on team 955. Our driver station is not displaying the voltage of the battery. It is only displaying 00.00. does anyone know what causes this to happen?
Re: Driver Station Voltage Problem
Did you jump pins 1 and 2 on the analog bumper?
EDIT- They are the two outside pins on the set of three to the left of the actual analog pins. You should NOT jump any of the actual analog pins. |
could like explain that a bit more
See page 12 of the Getting Started with the 2012 Control System document where it describes setting up the Analog Breakout. It refers to the Analog Breakout datasheet, which has detailed pictures showing what to connect.
| Driver Station not displaying Battery Voltage | Doc Wu | FRC Control System | 7 | 23-02-2010 16:03 |
| Personal Computer Problem With FRC Driver Station | Pewter_Newb | General Forum | 2 | 19-01-2010 23:26 |
| Can't change team # (was: Driver Station problem) | Lilszamora | FRC Control System | 2 | 03-02-2009 16:26 |
| Driver station problem | team2491 | FRC Control System | 7 | 31-01-2009 00:18 |
| Problem Downloading Program from WindRiver to Driver Station | The_Laughing_ManMII | C/C++ | 10 | 09-01-2009 20:03 |
