Go to Post The game objectives are still the same, get boxes into your scoring zone, stack approximately half of them, run for the top of the ramp. So lets sit down, shut up, and start building robots. - ChrisH [more]
Unread 21-02-2010, 17:31
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
Question Reed switch on pneumatic cylinder
We would like to use an old bimba reed switch from a few years ago, however we are having problems with it. from what i understand, its just a magnetic switch that either swiches on, or off. We tested one with a voltmeter and a magnet and measured continuity between the two output wires. However, when we mount it on a cylinder with a 2'' bore, we cant get it to ever switch no matter where it is or where the piston inside is. Can anyone figure out what the problem might be? Does it not work on certain types of cylinders?
Unread 21-02-2010, 20:11
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Reed switch on pneumatic cylinder
It will only work with cylinders that are made for it.
Magnetic Reed Switch nickcvet89 NI LabVIEW 2 15-02-2010 21:40
pneumatic cylinder help. Brandon_L Pneumatics 2 26-01-2008 10:55
Pneumatic Cylinder yanksrock777 Technical Discussion 2 20-02-2007 11:01
Magnetic Reed Switches and cylinder boom positions???? cdennisxlx2 Pneumatics 7 11-07-2006 21:17
is the reed switch legal? Anne Lam Technical Discussion 3 14-02-2002 12:39
