Go to Post Backwards PWMs happen to the best of us. - Woolly [more]
Unread 21-02-2010, 17:37
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
Team Role: Leadership
Rookie Year: 2007
whatabouteve is an unknown quantity at this point
Rotata Camera image and Timer usage
these are the only 2 issues left on the entire robot code.
1 we cannot seem to be able to rotate the image of the camera 90 degrees on the dashboard.
the other issue is that we cannot seem to make the timer work. and after we added the timer code that compiled we got watchdog errors that have never occured before.
can anyone help with this.
Unread 21-02-2010, 19:09
Re: Rotata Camera image and Timer usage
I see a subVI called IMAQ Rotate. If you insert that on your dashboard it seems like it'd do the trick.
Is is in the Image Manipulation palette, or you can search the palettes.
The watchdog is probably because you are delaying the completion of your teleop, thus the watchdog is not being fed often enough.
Greg McKaskle
Unread 21-02-2010, 19:16
AKA: Dean Keithly
Rookie Year: 2007
this is C++ you're talking about? because it sounds like Labview
Unread 21-02-2010, 21:52
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
he is talking about the dashboard, which is done in labview, however i do seem to recall a setting for the axis camera that rotated the image, i will see if i can find it for you
Zme
EDIT: i just checked and that parameter only allows rotations of 0 and 180 which is a little ridiculous if you ask me but thats life i guess
Unread 21-02-2010, 22:25
The API from Axis has four rotations, (0, 90, 180, and 270), but the Axis 206 only supports (0 and 180). IMAQ Rotate takes a floating point number of degrees.
Greg McKaskle
Unread 21-02-2010, 22:27
Zme Zme is offline
FRC #2619
still seems a little odd but ok, thanks for the explanation
Unread 21-02-2010, 22:43
Perhaps the M1011 supports the other angles. I couldn't find the parameters list on their web site, but web server in the camera can provide a list of the parameters and valid values. It is a little hard to find, but if someone wants to log in and poke around.
Greg McKaskle
Unread 21-02-2010, 23:58
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
We've seen several watchdog issues this year, but have always tracked them down to problems in our code (mis-connected sensors that hang when initialized, wait() calls in IterativeRobot, etc.). You must not be using the Timer correctly. It works (we are using it at least). Perhaps some sample code might help if you don't find it yourself.
Michael Andrews
Team #281 Programming Mentor
Unread 22-02-2010, 06:07
AKA: Dean Keithly
Rookie Year: 2007
thanks for the info on the camera. We've ha a hard time finding timer code because it is probably so simple. we're chunking up the code and rerunning all the stuff in it.
one baby step at a time.
Camera ROI Usage? buddyb C/C++ 1 06-02-2010 20:19
Timer vi's and Watchdog Rafael Vasquez Programming 1 28-01-2010 18:38
Camera Usage Jaime65 Technical Discussion 5 02-02-2007 21:39
EasyC Timer and Gyro questions TubaMorg Programming 11 09-02-2006 21:19
Timer Interrupt 1 and the IR tracker Mr. Lim Programming 0 25-01-2004 22:53
