Running a Relay for a Set Time
I need to run a relay for a set amount of time while still being able to run the rest of the robot's functions. When I use the tried and true Wait() function from the Watchdog, it (as expected) halts the rest of robot operations. I have looked into separating out this function in a Task/Semaphore formation, but I'm not sure if it will solve this or exactly where to start with this (I have looked through this tutorial, but I'm still not sure where to start). What is the best way to run a function for a set amount of time while still running drive/other schmazz?
| HELP!!!EMERGENCY!!!RUNNING OUT OF TIME!!! | furiousgeorge | Programming | 7 | 02-12-2009 02:05 PM |
| 2791 Bot running around for the first time | yodameister | General Forum | 5 | 02-08-2009 04:30 AM |
| Set Up Time At Regionals | fatjoe3833 | Regional Competitions | 13 | 03-25-2006 12:04 AM |
| Running a motor for a set time in auton | Morgoth | Programming | 5 | 03-11-2003 01:59 PM |
| Time is running out... | archiver | 2001 | 0 | 06-24-2002 12:04 AM |
