Go to Post The worst that happens is we try our best and lose. And there's no shame in that. - pfreivald [more]
Unread 21-02-2010, 17:59
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Team Role: Mechanical
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Riveting the wheel tread?
We keep losing the tr5ead on our Andy Mark plaction wheels, and we were wondering if riveting the tread to the wheel would constitute as metal-to-carpet contact...
I tried searching the Q&A, and CD, but I did not find an answer to this question.
I would post a question to the Q&A, but the only person who knows the username and password for our team is not here, and busy...
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 21-02-2010, 18:01
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Riveting the wheel tread?
As long as the rivets don't contact the carpet, you should be OK. Make sure they're sunk deep.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 21-02-2010, 18:10
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
A good question... we're using IFI (VEXPro) traction wheels, which use a similar method of attaching roughtop tread to the wheel. The particular rule regarding metal-to-carpet contact has not changed in years, and IFI wheels have passed inspection many, many times in the past.
If the interpretation of this rule were going to change for this year (seeing as how the rule hasn't) then we should have been informed prior to today.
That said... I've sent the kids back to "do a better job" of riveting the tread on more than once already. Part of keeping this method legal, is making sure that a bad rivet doesn't damage the carpet.
Jason
Unread 22-02-2010, 09:43
Kage's Avatar
AKA: Kage
okay, thanks.
we were just curious, because this is the first year that we have used wheels with detatchable tread.
I did some testing with different sized rivets, and figured out what worked...
thanks again!
Unread 22-02-2010, 09:49
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
I believe that we've used staples.
FRC Team 93 Alumni
Unread 22-02-2010, 09:50
Kage's Avatar
AKA: Kage
the ones we got came with staples on them, but the staples kept tearing out.
Unread 03-05-2010, 22:37
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is offline
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Nathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond repute
I'm contemplating using AM plaction or performance wheels for an off-season drive train... Have the rivets been successful at holding the treads on? What size wheel are you using? Do you have any plaction vs. performance comparisons to make? Thanks for the time!
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 03-05-2010, 23:09
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Rookie Year: 2007
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
We actually used both Plaction and Performance wheels (6") on our robot this year. We used rivets to hold the tread on both types of wheels, and never had an issue with the tread coming out. I would suggest using more than just 4 rivets at the very ends of the tread. Maybe 2-4 in the middle of the length of tread. With regard to Plaction -v- Performance, we used Performance for the wheels that were taking the brunt of the force coming off the bump to ensure that the Plaction wouldn't break, but we never had issues with either. However, on thing to consider is that the Performance wheels are just slightly larger (circumference) than the Plaction wheels, so if you are using some of each, make sure you account for that (especially if you want to make a 6 wheel-rock drive train.)
-Seth
Mens et Manus
Unread 04-05-2010, 06:42
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Originally Posted by AndyMark
Roughtop or Wedgetop conveyor belt material are used as replaceable treads on these wheels. For best use, install rivets into each end of the tread to insure the tread stays put under heavy usage
http://www.andymark.biz/plactionwheel.html
It says right on the page where you can buy them that the best way to get them to stay is to use rivets. We used two at each end of the "belt".
Like that.
Unread 04-05-2010, 10:21
CN-U-NEFCU? CN-U-NEFCU? is offline
roboticeagle
AKA: Nolan
FRC #0358
Team Role: Student
Rookie Year: 2007
CN-U-NEFCU? is an unknown quantity at this point
We also riveted the treads on after they had fallen off in a match, but be careful where on the wheel your rivets are placed. Our team ended up cracking a big piece of the wheel off in one match after it was weakened because the rivet whole was drilled through the split in the plastic causing a crack.
Unread 04-05-2010, 10:27
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
If you're putting a pop rivet into plastic try putting a small washer on the tail of the rivet for it to grip with, I've found that this really helps when riveting into materials that don't handle bearing stresses well, like plastic or carbon fiber.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Wheel/Tread Suggestions for Crab Modules Akash Rastogi General Forum 7 07-04-2009 04:18
Riveting for speed Richard Wallace General Forum 22 29-01-2009 06:41
Riveting up a frame Billfred Technical Discussion 27 19-12-2006 19:49
Tank Tread Wheel Joe_Widen Technical Discussion 8 29-05-2006 23:28
HELP us get rid of this wheel tread! sanddrag General Forum 3 23-01-2005 01:42
