Go to Post Please share your opinion and post whatever you want, I wouldn’t mind. Because I may be wrong. - Arefin Bari [more]
Unread 02-21-2010, 07:09 PM
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
Interrupt for DIO?
Hi,
We're using a DigitalInput wired to a limit switch to stop a motor from turning. (It needs to be overridden with a button, so we can't use the Jaguar's built-in limit switch port) We are not able to check the value of the limit fast enough to stop the motor immediately. Is there any way to implement an interrupt on any pin of the sidecar? I've searched all over the forums and can't find anything. Let me know if you are aware of any way to set up an interrupt on a DigitalInput. Thanks.
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 02-21-2010, 07:18 PM
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Interrupt for DIO?
How fast do you need it to stop? If you absolutely need it to be less than a couple dozen milliseconds, your best bet is to wire it directly to a CAN enabled Jaguar. Honestly though, I'd bet that you could get away with just checking every 5 milliseconds in a loop with a delay in it.
driver's station DIO and joystick wheel windell747 NI LabVIEW 2 03-24-2009 03:08 AM
DIO not working in autonomous. adamdb NI LabVIEW 10 02-12-2009 01:23 AM
Open motor reference on Slot 6 DIO Module trilogy2826 NI LabVIEW 2 01-27-2009 08:42 AM
Using DIO pin 14 as timer source? Jared Russell Programming 1 02-12-2006 12:02 AM
Gear tooth sensor / GTS on DIO 3,4,5,6? demerski Programming 5 02-07-2006 09:04 PM
