Go to Post "PWMed" - Sam N. [more]
Unread 21-02-2010, 19:56
diggoran diggoran is offline
FRC #1895
diggoran is an unknown quantity at this point
Diagnostics tab causes relay troubles
We've been having some difficulties with the relays on our robot. It seems to be working just fine for a while, but then the SPIKE relays go haywire. Why is it that these problems only occur while we are in the diagnostics tab of our Driver Station?
Unread 21-02-2010, 20:49
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Diagnostics tab causes relay troubles
The diagnostics tab has many more things going on in the background then the other tabs. For example, it is pinging the control system components. It's not expected that teams would be running their robots with the diagnostics tab open.
Unread 22-02-2010, 09:36
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Maybe not on the field, but I'd expected that teams will commonly run with the Diagnostics tab in the pits and on the practice field.
Not to be overly churlish, but I consider it a valid point of concern.
Unread 22-02-2010, 17:47
FRC #1895
The problem seemed to be fixed with a firmware update to the Driver Station. Problem solved. Thanks guys.
Where is the design tab located? Abole Inventor 9 17-02-2010 13:44
No robot diagnostics unobtainium-42 C/C++ 3 31-03-2009 09:50
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
Breaker Panel Diagnostics dm0ney Programming 4 29-03-2005 19:00
TAB command in Pbasic virusmirusne Programming 11 25-01-2003 02:51
