Go to Post What are you people going to rumor mill about if we ever actually get a water game? - Kevin Sevcik [more]
Unread 21-02-2010, 20:49
fordrew's Avatar
fordrew fordrew is offline
Rookie Year: 2010
fordrew is an unknown quantity at this point
Need Rules Clarification -- Battery
Hi,
I know that the electronics of the robot need to be isolated from the robot, but my coach heard while he was "scouting" other schools that the battery needs to be enclosed... I checked the rules and I have seen nothing so far about a rule about this. I know the exposed terminals need to be covered, but does the battery need to be enclosed? Our team created a clever little holder already but we do not want to spend the last day working on something that does not need to be done.
Thanks.
Unread 21-02-2010, 20:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Need Rules Clarification -- Battery
The battery needs to be secured, but not necessarily enclosed.
<R18> When positioned on the ROBOT, the primary battery must be secured so that it will not dislodge should the ROBOT be turned over or placed in any arbitrary orientation.
Breakaway is a very vigorous game, with rapid changes in orientation as the ROBOTS cross the BUMPS and a potential for significant interaction among ROBOTS. There is a high probability that your ROBOT will be overturned at some point. Should that happen, your design must prevent the battery from falling out and damaging itself, your ROBOT, or other ROBOTS.
Unread 21-02-2010, 20:58
fordrew's Avatar
Rookie Year: 2010
okay, thanks for the info!
Unread 21-02-2010, 21:38
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Keep in mind that there is expected to be a LOT of high-energy impacts during this year's matches (especially as robots drop off the bumps). Securing the battery within your robot is probably more important than ever. Inspectors will be carefully enforcing the "battery must be secured" rule (<R18>). No one wants to have a battery welded to their robot.
The rules may not require "enclosed" but they definitely require "secured".
Russ
Rules Clarification RyanCesiel Website Design/Showcase 7 10-02-2008 01:42
Clarification of Animation Rules McPhil General Forum 3 08-01-2008 22:57
Need Clarification of cost of additional Components rules Japper General Forum 8 10-01-2007 16:50
Rules Clarification archiver 2000 1 24-06-2002 00:28
Battlecry -- rules clarification ColleenShaver Off-Season Events 1 10-06-2001 16:44
