Go to Post A Guru teaching batteries at Exide: "Do not draw your power from up here, by your terminals. You must reach down deep into your plates and pull the energy from your entire being! You must prove yourself worthy to be FIRST power cells!" - KenWittlief [more]
Unread 21-02-2010, 20:50
Timing Tool
I've attached a VI that may give some insight into the timing of LV-based applications. Perhaps something like this will find its way into the default framework next year.
Drop the subVI into the teleop and into vision or periodic loops. You may want to wire a Call Name into the subVI, but if you do not, it will use the calling VI's name.
While running the robot code in development mode, you can open the subVI panel and look at the display of names and deltas. Hopefully it will give some insight into how often various portions of your code are being run. If the CPU is overtaxed, look for things you can increase the loop timing on. If the value for teleop is much larger than 20, it indicates an issue with the amount of time teleop is taking to run.
This will not solve any issues on its own, but it should be lightweight enough to leave in your code and will help you keep tabs on timings as code changes are made.
Greg McKaskle
Unread 21-02-2010, 22:42
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Timing Tool
Thanks Greg. I think this will be quite useful as both a teaching tool and a debugging tool.
Unread 22-02-2010, 02:16
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Timing Tool
Thanks Greg. I'm always grateful for a nice new tool.
(and thanks for that "s" at the end of your filename ... saving us from a rename)
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Timing belts kajeevan General Forum 6 13-08-2008 13:59
timing of re-contact Gary Dillard Rules/Strategy 16 19-01-2008 14:09
autonomous timing seanl Programming 6 09-03-2007 09:42
Timing Codes Ryan Cumings Programming 11 29-01-2004 22:26
Tool for one, Tool for all Gadget470 Team Organization 6 01-10-2003 02:41
