Go to Post and Bob's your uncle. - Joe Johnson [more]
Unread 22-02-2010, 00:35
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Team Role: Leadership
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Help at the midnight hour (electrical)
My team is having some major problems with some electrical components.
Our biggest problem is we have gone through 5 spikes for the compressor and none of them work. Even weirder they all don't work in different ways. All these spikes where either out of the box or lightly used once our twice (they worked before). The first spike actually worked for a time but then got stuck in the open position and won't switch. The second spike wouldn't even light up. The third spike had lose connectors and was stuck in one position. The fourth spike had ADD and would randomly switch even when the PWM cable and the Compressor power cables where disconnected, basically it only had power connected to it. Then the fifth spike again was stuck in one position but it was in the off position. Does my team have the worst luck in the world and just so happened to get 5 bad spikes, or is there something that could be fundamentally wrong with our electronics.????????????? I am not the best person to tell all about the exact electrical set up but as far as i know we followed the rule book exactly for all the parts. We got the recommended breaker on the power distribution board, the right gauge wire, the PWM cables are done right, etc... However if something that could be wrong in those regards could cause these problems please say so.
The problem with our electronics is we have a "lazy Jaguar" the jag in question has worked properly before but suddenly it isn't. According to the code the voltage going out of the Jag is the same as the rest of the wheels. However when we measure that voltage it is about 1/3 less than the rest of the jags. We haven't replaced it yet but We are worried that it might be something beyond the Jag because as i said earlier it worked fine for a time then this happened.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 22-02-2010, 00:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Help at the midnight hour (electrical)
In addition to the breaker on the power board, you need to remove the yellow fuse, and install a 20A black breaker into the spike.
Also...how are you connecting the spike? Did you connect the V+ V- side to the power board, and the M+ M- side to the compressor?
Unread 22-02-2010, 01:48
m-boyer's Avatar
m-boyer m-boyer is offline
FRC #2753
Team Role: Electrical
m-boyer is an unknown quantity at this point
Hey! Sounds similar to a few problems we've been having. I'd say definitely check if the PWM wire is good, and definitely check the DSC to see if there are possibly any metal shavings or conductive stuff inside it. Take it apart and blow it out if you have to. We've done that a few times.
Best of luck!
Unread 22-02-2010, 08:01
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Interesting..... 6 years and never a bad spike, and we had the one on our compressor fail yesterday mid-practice......
Light would not go green, even though it was getting signal, and I could feel the relay click. We changed it out with an old one. Opened it up and smelled 'smoke' but did not see any charred components.
We had changed the 20 amp fuse with a breaker.
Unread 22-02-2010, 08:10
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
All,
You definitely need to change the 20A fuse on the Spike feeding the compressor with a 20A circuit breaker because the inrush current when starting the compressor is too much for the fuse.
This is allowed by <R60> part F.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 22-02-2010, 08:37
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
For the "Lazy Jaguar" you might want to run the calibration routine and see if that fixes this problem.
Page 2/13 for the MDL-BDC Gray/MDL-BDC24 Black respectively of the "Getting Started" pdfs located here: http://www.luminarymicro.com/jaguar.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 22-02-2010, 08:46
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Mat,
I can believe one Spike and maybe really bad luck could get two but not five. What you describe sounds like a PWM cable issue. Remember that the Spike is not a PWM device. It is getting straight command signals using a PWM cable as a standard interface.
A common failure mode for Spikes is caused by rough handling. Pulling on the input and output power connections causes the 1/4" male "push on" to pull out of the circuit board. Test the tabs by wiggling with your finger. If they move around they have been pulled out of the circuit board. In most cases, a person who is good with a soldering iron can simply push them back into the board and resolder. Moral of the story is don't wiggle the push on terminals while you are trying to insert or remove them from the Spike.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 22-02-2010, 10:20
Thanks all we will do all the things you mentioned tonight
Help. Electrical or Mechanical Engineering? ginosoprano09 College & University Education 16 30-11-2009 09:22
Cero and Electrical Help! marisaDKNY Electrical 2 13-01-2009 21:41
electrical & pneumatics help samir13k Electrical 4 01-12-2008 18:38
Earth Hour! Save the world one lightbulb at a time! KelliV Chit-Chat 8 30-03-2008 20:43
So who else is up byrning the midnight oil finishing the safety animation? Koko Ed 3D Animation and Competition 8 16-12-2004 16:16
