Go to Post REAL WORLD = TOP PERFORMANCE... otherwise, get used to Ramen Noodles dinner or living in your childhood bedroom. - Michael Blake [more]
Unread 22-02-2010, 11:31
Josh987's Avatar
Josh987 Josh987 is offline
That's what I say.
AKA: Josh
FRC #1565 (Think Tank Tech)
Josh987 is an unknown quantity at this point
Crio-Sidecar
Our team is experiencing some problems, it seems, with the sidecar or maybe the crio. The problem is that when the motors start to go somewhat forward maybe 50% or so the 5v light on the DS goes off and the all the jags turn slow yellow. We are using 4 wheel drive, and after much trouble shooting we are certain it is not the code. We have figured out though, if you unplug any of the two jags the problem goes away. One other thing we have noticed is that if we toggle the disable/enable button after it stops working the 5v light turns on again, but the same problem will occur. My team doesn't know where to go with this, any help is very much appreciated. The first thread started out in programming because we originally thought it was a code issue. Here is the link http://www.chiefdelphi.com/forums/sh...ad.php?t=83281
Charlieeeeee, Candy Mountain
Unread 22-02-2010, 13:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Crio-Sidecar
What do the other power LEDs show you? This sounds very much like your Digital Sidecar is not getting 12 volt power. Check its power input to make sure the wires are correctly connected to a 20 Amp circuit from the Power Distribution board. Correctly connected includes the right polarity (plus to plus, minus to minus) and the right amount of insulation stripped so that the Wago connection is made properly.
Unread 22-02-2010, 14:09
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Crio-Sidecar
Sounds to me like your battery is low. When you draw high current from your 4 cims the battery voltage will drop. If the battery voltage is too low then the cRIO will go into protect and disable everything until the voltage rises again.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 22-02-2010, 14:46
Josh987's Avatar
That's what I say.
AKA: Josh
Re: Crio-Sidecar
We used a charge battery and switched to another charged battery just in case.
Unread 22-02-2010, 14:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: Crio-Sidecar
Make sure the jumpers for the 5V supply aren't in for the Jaguars. I don't know if it will make any difference, but they certainly don't need to be there, and the Jaguar's should have the 5V connection open internally. You should only use them for servos. This should make no difference, but it's worth a shot...
Make sure all the connections are tight. Disconnect everything from the side car, then reconnect all of it. Do this for the cRIO Module as well. Check the 12V supply as already suggested. Make sure the PWM Cables are in the correct way.
If none of that works, I would begin thinking about ordering a new Sidecar as it shouldn't cut out like it is.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 22-02-2010, 15:08
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Crio-Sidecar
Could we get more details on the drivetrain? Specifically the following:
Length between wheels?
Width between wheels?
Type (KOP, roughtop, wedgetop, etc.) and size (6", 8", etc.) of all 4 wheels?
Motors? (eg. 2CIMS, 4CIMS, etc.)
Gearbox ratio?
Sprocket ratio between gearbox and wheels?
If you are running a 4 wheel drive with all traction wheels that is much longer than it is wide you may be drawing enough current to draw the battery down to a very low voltage. Can you see what the battery voltage is doing on the Driver Station when this behavior occurs?
Unread 22-02-2010, 15:58
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Crio-Sidecar
Is your DSC connected to 12V power directly from the PDB into the WAGO connector on it? Alan was alluding to a problem that can arise where the DSC gets enough juice to run through the NI module in the cRIO, but when you start changing the outputs, it browns out, which sounds like EXACTLY whats happening here.
Unread 22-02-2010, 22:22
Josh987's Avatar
That's what I say.
AKA: Josh
Re: Crio-Sidecar
The problem was we had the power wires reversed. After that everything worked well. Thanks very much for all the help.
cRIO-sidecar communication NoahLitle Electrical 1 21-02-2010 21:04
digital sidecar J1 pinouts (cRIO connection) stevethetinker Programming 0 09-02-2010 21:34
Changing Crio Digital Sidecar input slot from slot 4 to 5 Trevor_Decker Java 9 28-01-2010 12:29
Digital sidecar cable Noamr Inventor 1 22-02-2009 15:56
Sidecar Debug NinjaSpawn94 NI LabVIEW 6 07-02-2009 10:48
