Go to Post Note to self: Go to IRI sometime. - [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 22-02-2010, 13:34
JasonStern JasonStern is offline
Mentor
FRC #1123 (AIM Robotics)
JasonStern is on a distinguished road
CAN Jaguar enhancements
Our team has noticed a couple of areas in the (Java) CAN Jaguar code we would like to modify:
* Always send speed and position references no matter the control type
* Adding the ability to switch control types on the fly
Are there any hardware/firmware/software reasons that would prevent these changes?
The first change is because we discovered the Jags will not return a speed value in open loop control mode unless code had previously been loaded to the crio prior to rebooting that put the Jags in closed loop control mode (speed control). We have motor calibration code that depends on receiving speed values in open loop mode.
The second change is so that we can switch between position and speed control for different operations (autonomous and teleoperated).
We can just make the changes and try it out, but we have already bricked our spare Jags and don't want to risk it. (We also don't have any Black Jags for recovery.)
Thanks,
Jason
Que será será
CAN Jaguar Malfunction PranavSathy CAN 4 21-02-2010 18:32
CAN Jaguar Synchronous Updates?? Bryscus Programming 3 30-01-2010 16:13
Getting started with CAN/Jaguar CVassos Programming 1 27-01-2010 23:43
CAN bus Jaguar intermittent errors bear1511 Programming 1 27-01-2010 22:49
Black Jaguar RS232->CAN - anyone? oddjob C/C++ 12 22-01-2010 16:25
