My team is interested in putting a lock on our crate. Would it be allowed for the lock to be sticking out of the parameters of the crate if the crate itself is in the allowed dimensions?
Re: Crate design
Just out of curiousity...what would be the point of a lock? I really doubt anyone will be messing with it...and if they really want to a lock won't stop a FIRSTer.
Re: Crate design
Our design was to have swinging doors so it would be easier to unpack once at the competition. In order to keep the doors closed at all times until we would need it, a lock would be needed.
Re: Crate design
We have used locks for the past four years, and never had a problem with them.
Re: Crate design
Haha I kind of agree with that. Im sure if someone actually wants to get to it, a simple padlock is not going to get in the way if there are thousands of dollars of robot on the other side
Re: Crate design
Zip ties might be better. Or just screw a thin piece of plywood, maybe 2 ft by 1 ft, over the door joint to keep it closed.
The lock will not stop anyone from getting inside, for several reasons. - the least of which is that most FRC teams have to tools to disassemble the crate in a jiffy. |
Re: Crate design
Most teams use a lock(s) on their crate. Please keep in mind that the crates are going to be handled by fork trucks and freight handlers not the post office. If locks stick out they are going to catch on stuff and be pulled off or damage the crate.
Re: Crate design
We just screw our crate up tight.
But then, we're good at screwing things up. Jason |
Re: Crate design
Re: Crate design
It is better then screwing around.
#11
Re: Crate design
Or having a screw loose!
#12
Re: Crate design
The coolest crate I ever saw was by the Grundy Va team.
It was made out of diamond plate aluminum and had those flush latch handles like are on the equipment doors of a fire truck. |
#13
Re: Crate design
You could search around and get those "twist" locks that are on the field boxes.
Those would be less bothersome then a lock, would hold it tight together, and be flush inside the crate, so there is no chance of it getting busted off |
| Simple Crate Design and Kudos to Team 246 | Pjdaley13 | General Forum | 0 | 13-02-2010 20:55 |
| Crate design | nerd_dad | Technical Discussion | 0 | 06-09-2006 18:33 |
| crate design and construction | oreocookeee | Technical Discussion | 20 | 18-12-2004 02:32 |
| Save the rookies!!! Please help us to design a crate... | Eugene | Technical Discussion | 7 | 05-02-2002 20:22 |
