Go to Post it is easy. you will have to define "easy" in your own terms. - Mike Martus [more]
Unread 22-02-2010, 18:36
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Crio Problem
Hey my friends:
Two days ago our robot was working very good, yesterday I can't move sensors, camera, encoder.But only the motor can work I dont know why, is the same program, the same conextion, I changed the wires conexion but the problem is the same I am thinking if is the problem with Crio so I want to Know if could be this problem, What happens if I reset the Crio??? the problem is common???
Thank you!!
PD: What update I need for restart the Crio??
Crio Problem frcchile Control System 2 30-03-2010 10:21
cRIO output problem alex42 FRC Control System 1 27-01-2010 22:28
cRio problem specs101kid Programming 4 21-01-2010 16:19
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
