Go to Post All we know is the "Oh my God, No data/Radio...reset...reset" dance before our matches! - tenfour [more]
Unread 22-02-2010, 18:57
lucoytoa's Avatar
lucoytoa lucoytoa is offline
Programmer
AKA: Nicolas Xiong
FRC #2276 (STARS of Cypress)
lucoytoa is an unknown quantity at this point
Cool Motor Jerking when Reverse
We have a program that when button 1 is press, the motor goes forward, when button 2 is press, the motor reverses. When button 2 is press, the motor jerks and moves very slowly. Moving forward is fine. Please help!!!
We've tested on several motors, jaguars, changed pwm, and still having the same problem.
Here is our code:
Unread 22-02-2010, 21:50
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
Re: Motor Jerking when Reverse
The code is a little difficult to read, and it would be beneficial to clean up the wiring to help with any problems. However, it appears that you have a joystick axis value going to a case statement rather than a button press, as indicated by the orange wire, rather than a dashed green bool wire.
http://www.wcsrobotics.com
team 663
team 1493
Unread 23-02-2010, 10:54
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Plus, you've got two Motor Set Speed vi's to the same motor with conflicting speed values.
Try something more like this:
or this:
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 31-03-2010, 14:25
lucoytoa's Avatar
Programmer
AKA: Nicolas Xiong
Thanks! That sure made it a lot less messy- and less complicated. I won't be able to test it until tomorow when we actually get to see the robot again. Anyway, thanks for the help!
Robot doesn't respond when i add a fifth motor starsROBOTICS NI LabVIEW 2 14-02-2009 22:40
forward reverse on drill motor PDonovan Motors 2 03-02-2003 11:11
Reverse Engineering the Drill Motor Andrew Motors 1 05-01-2003 16:14
Difference in forward/reverse drill motor speed archiver 2001 25 24-06-2002 00:21
Drill Motor Anti-reverse Pins... archiver 2000 5 23-06-2002 23:10
