Go to Post You are an inquisitive rookie aren't ya - Kyle [more]
Unread 22-02-2010, 19:10
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Rookie Year: 2010
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Main Battery Voltage
This year we are wondering if it is still mandatory to display the battery voltage for the robot on the dashboard. The most recent driver station updates do not include in their default projects a battery voltage monitoring system. Even if it is not mandatory how could we measure the voltage.
P.S. we are a rookie team
P.P.S. we really don't know what we are doing
Unread 22-02-2010, 19:24
helenajoy helenajoy is offline
FRC #2437
helenajoy is an unknown quantity at this point
Smile Re: Main Battery Voltage
I am pretty sure that our programming team has installed all of the recent updates for both our LabView program and our Driver Station. We are still able to receive battery voltage information from the Driver Station...
On the Driver Station, is it only the battery voltage that you cannot see? Are you still able to see your Team Number at the top of your Driver Station? If you are not able to see your Team Number, the problem may be that your Driver Station isn't properly communicating with your robot.
Ah, I apologize if I am not much help.
Unread 22-02-2010, 19:37
Carter12s's Avatar
Team Cap
Rookie Year: 2010
thank you for trying but the robot and everything is in communication there is just no spot on the dashboard for the on board battery voltage. we have the laptop voltage just not the on board voltage.
Unread 22-02-2010, 21:38
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Can you post a picture of the display? The battery voltage is on the far left of the driver station software, for me.
Unread 22-02-2010, 21:41
DonRotolo's Avatar
Back to humble
FRC #0832
See <R66>
Unread 23-02-2010, 00:10
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
If you cannot see your battery voltage from the Driver Station, you most likely do not have the jumper correctly on the analog breakout of your analog module in slot one.
There is a small PWM-style male header (without the blue plastic around it). You need a jumper on the outer two pins.
-- Marshal Horn
Unread 23-02-2010, 08:07
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The battery voltage monitor is pretty important when troubleshooting or in competition. If you are doing some maneuver that keeps drawing the battery voltage down, it is a good bet that at some point your Crio may inhibit output or reboot altogether.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 23-02-2010, 13:02
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
It is NOT included on the Dashboard but it is on the Driver Station.
Only the first seven (7) analog input are displayed on the Dashboard.
You do not have to display on the Dashboard, it on the Driver Station.
If it is not on your Driver Station do you see
Volts --.--
Under your Team #xxxx
Omar
Unread 03-03-2010, 17:00
Carter12s's Avatar
Team Cap
Rookie Year: 2010
Thanks everybody I found the problem. we had disconected AI moduel 1 and were using moduel 2 i found the driver station spot where it is displayed. Thanks!
Battery voltage Yuan Xue Lim Electrical 7 04-02-2009 23:10
Main Battery Cables maclaren Electrical 14 26-07-2006 12:37
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
Battery Voltage Neal Probert Programming 3 09-01-2003 10:18
