pic: Team 293's Robot
Re: pic: Team 293's Robot
We have a long history of using 80-20 and man that stuff is heavy!
i know... we use it for prototyping because it is easy to adjust the length of things... i was wondering how much that whole chassis weighs
We're puzzled when people say that 8020 is "heavy". Heavy compared to what?
The most common profile, 1010, weighs exactly as much per foot as 1 x 1 x 1/8 wall aluminum square tube or 1 x 1 x 1/4 angle. 8020 outperforms these materials in every way. The key to using 8020 is knowing how to join it without using joining plates, brackets or excess fasteners. This robot has only two joining plates, selected for convenience in servicing the drive train. The chassis pictured weighs in at 29 pounds; the entire robot, fully loaded, is 113. Weight was never a problem this season. |
How does this method hold up at competition? Do you put locktite or anything on the bolts? Do you have a problem with them staying tight? Looks great. Good work. |
Compared to .075 wall 1 inch tube it's rather heavy. But for me it has more to do with the aesthetic look of an 80-20 robot and the fact that doing things like non-45 degree miters seems to always need mending plates. Just my two cents. How do you join it without plates? Do you use those pieces that 80-20 makes that you counter sink into the ends? Or something else?
We counterbore clearance holes for 1/4-20 socket head cap screws (17/64 body, 25/64 head) and screw them into the tapped ends of the extrusion. McMaster sells a step drill bit to do this in one operation (drill press only!) Where 2 or 3 bolts would conflict at a corner, we use 8020 "end fasteners' which require only a #7 clearance hole for the hex key to tighten. Occasionally we use 8020 "anchor fasteners" which require a 9/16 counterbore in one extrusion.
We have done 45 degree and other angled connections. These require a careful drilling setup because of the profile shape. These connections remain tight without locktite, but we always check everything just in case. All of the fabrication steps for an 8020 frame can be learned by new team members very quickly, and the results are precise and as strong as they need to be. An 8020 frame is easier to put together than the Kitbot, and it is stronger, stiffer, and straighter. |
80/20 weight stacks up fast, mostly because of all the fasteners you need, and generally people use more of it to accomplish the same things. I'm looking at how adding a few more feet of it added 25 pounds to the robot the other night :/ Last edited by Chris is me : 23-02-2010 at 15:33. |
Looks good. I can't wait to see it in action.
![]() (My 272nd post, Go CyberCrusaders. )Cass |
#10
There are benefits to square tube and to 8020.
Weight wise, 8020 and 1/8" al are about the same. 8020 is about 2x 1/16" wall, which can be used in many places. I really like your attachment approach, which provides a big weight savings and space improvement without the corners and extra bolts and t-nuts commonly used. Very nice, and way to take advantage of capabilities you have and materials you have and come up with a great finished product. |
| pic: Team 469's Robot for 2006 pic 2 | Don Wright | Robot Showcase | 10 | 26-02-2006 21:03 |
| pic: Team 469's Robot for 2006 pic 1 | Don Wright | Robot Showcase | 11 | 24-02-2006 16:35 |
| pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! | sgsdragons | Robot Showcase | 4 | 01-03-2005 16:21 |
| pic: Team 237 Robot and Team | Scott Shaw 237 | Robot Showcase | 3 | 23-02-2005 19:54 |
| pic: Team 114 Real Robot Vs. Inventor Robot | James114 | Robot Showcase | 3 | 18-02-2005 13:02 |
