Go to Post Just fill your wheels with depleted uranium - EmileH [more]
Unread 02-22-2010, 08:39 PM
dcarswell's Avatar
dcarswell dcarswell is offline
FRC Mentor/Old Dominion University
AKA: DeAndre Carswell
FRC #3359 (Royal Robotics)
dcarswell is an unknown quantity at this point
PROGRAMMING HELP PLEASE !
Hello,
My name is DeAndre and I was wondering if someone could possibly tell me what is wrong with my code:
We have two Limit Switches on our Robot:
Limit Switch 1: When hit reverses Kicker Motor .
Limit Switch 2: When hit stops the Kicker Motor .
Limit Switch 1 is in front of Limit Switch 2 .
And also the Kicker Motor is attached to Button 1 on the joystick .
So when we press Button 1 it enables the Kicker Motor to move forward, then when it hits Limit Switch 1 it automatically reverses to consequentially hit Limit Switch 2 and stop. Then it should automatically reset it self back to its original state. (Hope I provided enough description)
Attached is our Teleop.vi !
Unread 02-22-2010, 09:09 PM
dcarswell's Avatar
Re: PROGRAMMING HELP PLEASE !
Here is also a picture !
Unread 02-22-2010, 09:10 PM
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
I would highly recommend checking out the FRC mastery site, especially the section on state machines http://frcmastery.com/try-me/state-machines/. The provided example is very similar to the method you are describing.
I hope this helps
http://www.wcsrobotics.com
team 663
team 1493
Unread 02-23-2010, 12:54 AM
anyheck anyheck is offline
FRC #2242 (Cougars)
anyheck is on a distinguished road
I think that you are encountering a problem because you are referencing the motor power three times with different 'set speed' VIs and are hitting some sort of race condition.
One thing that is not obvious is that the case statement can accept numeric inputs as well as Boolean inputs.
An 'easy' way to make a case statement that takes multiple booleans and does different things when they are set is to make a case statement and build an array of your booleans using 'build array'.
You can then wire the boolean array to "boolean array to number' operator and wire the output of that to your case statement.
Then you just need to use boolean math and put a motor speed value in each case.
00=0 -> (FF= case 0)
01=1 -> (FT= case 1)
10=2 -> (TF= case 2)
11=3 -> (TT= case 3)
So there you have 4 different values with two boolean inputs and you can just use one "motor set speed" vi.
Hope this is clear I don't have labview available at the moment or I'd take a screen shot.
Regards,
Sten
Unread 02-23-2010, 11:41 AM
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Also check the "Limit 1" string fed into the RefNum Registry Get.vi
You have two (2) spaces between "Limit" and the "1".
If that is the way you set it up in your Begin VI then you are OK
But if it is different that will cause you problems
Omar
Unread 02-23-2010, 11:50 AM
Omar's Avatar
This is what Sten is talking about.
Omar
Unread 02-23-2010, 03:48 PM
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
I believe I am trying to accomplish the same thing. I have 2 normally open switches which should turn off the relay motor once a true is recieved, which will be turned to a false, which is combined with a true from the joystick in a XOR (Not Exclusive Or) which will return false, which will turn it off. By default with nothing touching the buttons or switches, the relay should all be off, right?
Thanks
Name:	DIO swiches with relay.JPG
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 02-23-2010, 05:48 PM
Omar's Avatar
Let me restate what I think you want
IF Button 1 is pressed .AND. limit switch 1 is .NOT. true then run forward
else
IF button 2 is pressed .AND. limit switch 2 is .NOT true then run rev.
else
Stop
Omar
Unread 02-23-2010, 05:56 PM
kws4000's Avatar
AKA: Krazy Karl
Exactly
Mentoring:
Unread 02-23-2010, 06:37 PM
kws4000's Avatar
AKA: Krazy Karl
that's right
Mentoring:
Unread 02-23-2010, 07:56 PM
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
PLEASE HELP robot is due in 3 hours, and our C-Rio isnt communiting!!!!
WE TRIED WIRELESSLY USING THE ROUTER, WITH THE IP : 10.15.15.10, SUBNET: 255.0.0.0 GATEWAY 10.15.14.4 PLEASE HELP!!! IS SOMETHING WRONG PLZ ONLY 3 HOURS LEFT HELP IS MUCH AP[PRECIATED
Unread 02-23-2010, 07:59 PM
kws4000's Avatar
AKA: Krazy Karl
are you sure your ip addresses were correct? what you posted is 10.15.15.10
and 10.15.14.4, right? check the third set of numbers, they should be the same.
can someone please answer my problem now?
Mentoring:
Unread 02-23-2010, 08:10 PM
FRC #1514 (Vikings)
yes i have:Classmate :
IP: 10.15.14.10
SUBNET 255.0.0.0
GATEWAY: 10.15.14.4
Unread 02-23-2010, 08:14 PM
kws4000's Avatar
AKA: Krazy Karl
Are the bridge(robot) and router(DS) correct?
Mentoring:
  #15   Spotlight this post!
Unread 02-23-2010, 08:24 PM
FRC #1514 (Vikings)
DENINATELY (dont mind my spelling only got 1 hour till robot due )
we had it working like 3 hours ago. SUDDENLY STOPPED!!!
Urgent Programming C++ help please! Tds123 Programming 5 01-25-2010 03:21 PM
Programming help please?? programmr Programming 1 02-05-2009 11:40 AM
MPLAB PROGRAMMING PLEASE HELP!!! cstringer Programming 6 01-20-2008 01:49 PM
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 03-15-2007 03:11 PM
Please Help: Programming the Robovation Kit wmurphy Robotics Education and Curriculum 14 12-08-2004 12:57 PM
