Go to Post Not all creativity is visible or mechanical! - dtengineering [more]
Unread 22-02-2010, 22:12
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
What Are You Doing During Autonomous Period?
I think we are just going to spin for 15 seconds, compressing air during that time... We cant track the ball and our kicker isnt even accurate, we are just bombing it toward the goal...
Unread 22-02-2010, 22:16
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: What Are You Doing During Autonomous Period?
We are going to kick our balls, then do something else. Our selector switches select that something else, so it will vary, but there will be no more than 4 of those something elses per position. I would suggest at least getting/starting out of your partners way in case they want to kick balls.
Kettering Motorsports
Unread 22-02-2010, 22:24
Chris is me's Avatar
AKA: Pinecone
You shouldn't need to track the ball. It starts exactly where you put it every match.
You are also allowed to precharge your pneumatics, so you shouldn't need to use auto mode to do that.
What my team WAS going to do in auto was to have several modes with an adjustable 0-15 series of switches for delay. Then we got the kicker working an hour before we had to crate, and we still lack a posession mechanism. So... probably just 3 autos, "kick em forward".
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
we have a vacuum on our robot that makes for great consistency in the autonomous mode. our robot has a photo transistor on the front to detect balls that are in the vacuum, so we just line them up, go straight, grab a ball, kick, and move on to the next one. there are switches on the driver station that tell the robot what zone its in, so it stops after it hits the proper number of balls and raises the kicking mechanism for close shots.
Unread 22-02-2010, 22:32
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
we are going to drive up to the bump and turn to get over to the ball return to setup for our strategy
Unread 22-02-2010, 22:49
hyperdude's Avatar
hyperdude hyperdude is offline
Techie.
AKA: Mike W.
FRC #2503 (Warrior Robotics)
hyperdude has a spectacular aura abouthyperdude has a spectacular aura abouthyperdude has a spectacular aura about
As far as I am aware, our programmer has not done anything for autonomous. I think there's been a few ideas floating around, but now all we're going to be able to do is wait til April 1 to test any of them (our robot is crated up and ready for tomorrow).
Unread 22-02-2010, 23:55
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Position 1:
Move foward, kick. repeat 1 times.
Position 2:
Move foward, kick. repeat 2 times.
Position 3:
Move foward, kick. repeat 3 times.
Thats it. Simple, right? wrong.
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 23-02-2010, 01:20
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I think you might want to stick "aim" in there at some point, but even if you can't aim you should have the ability to at least kick or push 1 ball into the goal since you're free to line everything up in a straight line anyway.
Unread 23-02-2010, 01:35
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
As of right now, our kicker is cocking back to full discharge position and it blindly firing into the stands. This is not safe. refer back to my other posts about safety being for squares: comprised of the 4 staples in safety including Proper training, proper attire, common sense, and protection.
Unread 23-02-2010, 02:42
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
You also need to think about not blocking
the kicks of your alliance partners during
autonomous.
Unread 23-02-2010, 08:29
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Our autonomous program isn't completely debugged, but we've programmed it so that it should drive toward a ball, stop when our ball detector sensor detects something, aim at the goal with our vision tracking, kick, realign, then loop that depending on what zone we're in. We also sort of programmed encoders to track our position in autonomous mode so we don't go too far (especially if our gyro or something else goes wacky and we end up crossing zones).
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 23-02-2010, 08:44
Kibaspirit's Avatar
Kibaspirit Kibaspirit is offline
Team Captain
AKA: Brittany
FRC #2645 (Power Surge)
Team Role: Mechanical
Kibaspirit is an unknown quantity at this point
Send a message via AIM to Kibaspirit
Our robot goes to one side to find the wall (We have mechanum wheels) then tracks and shoots a ball. It can clear a bump. [:
2010: Innovation In Control Award (West Michigan)
2010: Traverse City District Champions (Alliance #1)
2009: Traverse City District Champions (Alliance Captain #1)
2008: Kettering Rookie Regional: Gracious Professionalism Award
"In the great swimming pool of life, there's always going to be a little pee."
http://www.rprobotics.com
Unread 23-02-2010, 10:16
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
We will be doing something fantastic in autonomous! Hopefully.
Unread 23-02-2010, 10:21
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
As of last night our first routine:
  • Arms the kicker (We come on the field with air)
  • Rolls forward at 1/2 speed to the first ball
  • Kicks towards the goal
  • Rearms the kicker for teleop
  • Stops
We also have a end of match routine that "kicks" one last time so that the robot is safe to move by the crew.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
  #15   Spotlight this post!
Unread 23-02-2010, 10:26
3286's Avatar
3286 3286 is offline
AKA: mike s
FRC #3286 (the Rock-It surgeons)
Team Role: Teacher
3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of
Well to be honest, as I type this...we will be hoping that something functions as intended and hasn't caught fire or broken in half!
I had to throw that out there, if half of us are half as tired and have spent half as much time as what I suspect working thru this project, then there are a whole lot of us out there who need a day to rest and recharge!
GOOD LUCK
Mike
What are you doing for the flooring? Petey Kit & Additional Hardware 21 06-01-2009 20:01
What are you doing Saturday night? Titan Championship Event 9 09-04-2007 12:58
What are you doing this year? 358_4_Life Rules/Strategy 4 16-01-2007 17:23
What do you do during autonomous mode? Salik Syed Programming 46 21-03-2004 21:05
What are you guys doing so far to practice. fs_2002 Technical Discussion 11 24-10-2002 10:21
