Manipulator not showing
Not even sure what its called, but for lack of better term I call it a manipluator... and I don't mean the gizmo...
One of installs of 3DSMax 2010 had the rotation / move / scale manipluators turned off. Someone hit a hotkey (not knowing which one) and the axis arrows, rotator circles, scale triangle do not show when trying to manipulate an object. We can't find out how to turn them back on. |
Re: Manipulator not showing
Under "Customize" go down to Preferences, and that should open up a menu of options. One of the top tabs is the "Gizmo" Tab. There you can turn the gizmos on and off.
Hopefully that can fix it. |
3ds Max Hotkeys:
Transform Gizmo Toggle: X SteeringWheels Feature (new in 2009): Shift W ViewCube Visibility (new in 2009): Alt Ctrl V |
Awesome - Thanks!
| Driver station not showing screen | scientificsax | FRC Control System | 9 | 15-02-2010 10:29 |
| Camera just not showing up.. | koo_04 | Programming | 5 | 31-01-2010 19:47 |
| Labview labels not showing up correctly | Hazmatt | Programming | 3 | 10-03-2009 17:08 |
| [FTC]: Help requested, the NXT is not showing the battery as being connected. | crazilyrandom1 | FIRST Tech Challenge | 2 | 17-01-2009 11:24 |
| Michigan District Stuff not showing up in Portal | Ken Patton | CD Forum Support | 8 | 07-08-2008 14:45 |
