Go to Post Ship day is a sweet and sour day. You're happy to see your robot ship, but then you start going through robot withdrawl - Schneidie [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 23-02-2010, 10:31
annie1939's Avatar
annie1939 annie1939 is offline
AKA: Ann Fairburn
FRC #4388 (Ridgebotics)
annie1939 has a spectacular aura aboutannie1939 has a spectacular aura aboutannie1939 has a spectacular aura about
Check the diameter of your soccer ball
When is size 5 not a size 5
This game looked like a straightforward challenge, but it has been nothing but frustration for our team.
We have spent a week tweaking our ball controller. We were analyzing pictures and videos of other rollers. We read all the discussions looking for clues. We measured pictures to make sure our roller was hitting the ball at the same location. We added rollers, wheels. We lowered and raised it. At one point we even covered it in the pink flannel that we make our bunny ears out of. We turned up the speed, lowered it. Made it stickier. Made it slicker. Covered it in teflon coated baking parchment. We knew our ball was stickier than the actual ball, but figured the official balls might get scuffed up enough during the game that it would be similar. Besides they were cheaper and we could get them. Nothing worked.
Finally, at midnight last night one of the soccer players on the team said the ball seemed a little heavy. They made a late night run to Walmart and got a fancy $20 dollar ball which was nice and shiny. Not only that, it was at least an inch smaller in diameter. Both balls were labelled size 5. We put the new next to the roller and it worked. It slipped on the carpet just like the pictures. Days were lost messing with the roller and it was the ball that was the problem!! The worst part is that since we lowered the roller to hit the ball, our kicker only swings far enough to tap the ball now. AAARRRGGGHHH!!!
So check your soccer ball if you can't get your roller to work and next year we will order the game pieces within the hour after kickoff.
Ann
Unread 23-02-2010, 11:32
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Check the diameter of your soccer ball
Originally Posted by 6.3.1
Each BALL is a standard Size 5 soccer ball. The BALL weighs between 14 and 16 ounces, has a circumference of 27 to 28 inches, and is inflated to a standard pressure of approximately 9psi.
These are standard FIFA (international football/soccer) definitions. As you note, you should have measured.
(since 2004)
Unread 23-02-2010, 18:45
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
At the scrimage this past weekend I checked 12 plus balls for the correct pressure. I found some as low as 5 psi and a few at 15 psi. I only found a few that were between 8 to 10 psi (spec). One of the best tools we bought early on was a ball pump and pressure gauge
Soccer Ball Sold Out topgun General Forum 72 06-03-2010 23:18
'Elasticity' of the soccer ball... coldfusion1279 Technical Discussion 7 17-01-2010 13:28
Soccer Ball CAD Model mplanchard SolidWorks 0 17-01-2010 00:29
Soccer Ball Correction adambspaulding Technical Discussion 3 09-01-2010 14:26
size soccer ball newatthis General Forum 1 15-01-2002 14:06
