Go to Post Think about the other teams...today your opponent, today your teammate. - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 23-02-2010, 17:45
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Digital Sidecar relay ports: correct voltage?
Can anyone please tell me what is the correct voltage reading on the red&white wires coming out of the relay ports on the digital sidecar?
We are measuring 4.2 volts in the active state.
We have a Spike relay connected to a relay port, and the Spike is not working.
By "not working", I mean the Spike LED remains orange and there is no voltage across the Spike's output. We thought maybe the sidecar got damaged and is not outputting the right voltage.
There is 12 volts across the Spike input, correct polarity.
The battery is sufficient; it runs the motors that drive the wheels.
We swapped out the Spike and the new one doesn't work either.
We understand the following chart and tested all four states
red=0 white=0 brake (both outputs grounded)
red=1 white=0 reverse (reverse output polarity)
red=0 white=1 forward (normal output polarity)
red=1 white=1 brake (both outputs +12)
Unless there's something I'm missing, the only hypothesis that seems to fit the facts is that the signal voltage is not correct.
Relay Ports on the Digital sidecar have no Power 10uhingp Electrical 6 30-01-2010 14:00
Attaching a standard car relay to the Digital sidecar KillerGardevoir Electrical 4 02-08-2009 21:26
Digital Sidecar Ports are dropping out. Tom Line Electrical 19 10-04-2009 00:55
Ultrasonic sensors on digital ports 3-6 problems wt200999 Programming 14 13-02-2008 08:13
LED's on Relay Ports? Kingofl337 Control System 5 18-01-2008 14:39
