Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Unread 23-02-2010, 18:50
drtysteve384 drtysteve384 is offline
AKA: Christian
FRC #0384 (Sparky 384)
drtysteve384 is on a distinguished road
Compressor not stopping at 120psi
Our compressor want stop at 120 psi for some reason and i was wondering why it wouldn't...Please i need help
Unread 23-02-2010, 18:55
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Compressor not stopping at 120psi
What is the wiring on your pressure switch?
What are you doing in programming to stop the compressor?
These are just a couple of pieces of information that will help troubleshoot.
Also, is your relief valve tripping at 125 PSI? (This will be inspected at competition.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 23-02-2010, 19:01
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
First - check across the terminals of the pressure switch with an ohmeter while you are pressurizing the system. I think it is a normally closed switch so you should read some resistance value until you reach about 120, then it should go to off-scale because the switch has opened. If you don't see that happen, you have a bad pressure switch.
Next, check on the driver station what you are seeing from the digital I/O port where you have the pressure switch as you go up in pressure. It should read true as you go up then change to false at 120 (or vice versa). If you don't see this then you have a bad connection somewhere between the switch and the cRIO - check the wiring.
If those are both good, your problem is in software. There is a pressure switch vi that should be running all the time - make sure you have it in place.
Close enough to taste it, too far to reach it
Unread 23-02-2010, 19:29
Kallenberg Kallenberg is offline
FRC #0447
Kallenberg is an unknown quantity at this point
447 Had the same problem. We had to replace the Digital side car.
Unread 25-02-2010, 10:11
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
I'll vouch for that one. Ran into a rookie team at a regional last year that we couldn't figure out why their compressor wasn't shutting off. Eventually they replaced the sidecar and it fixed the problem.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 23-02-2010, 20:01
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Will the pull-up resistor in the DIO confuse the ohmmeter reading ?
Unread 23-02-2010, 20:16
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
Team Role: Mechanical
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
If the controller is on: use the voltmeter to measure 0 or 5v across the switch. If 5v the switch is closed (115 psi) if 0v the switch is open ( less than 95 psi). If that is working correctly then try measuring at the end of your pwm cable (where it attaches to the sidecar), if that is still working do a print statement for the digital input you are using. You should see it go high (1) when the sensor trips at 115 psi. If not, your sidecar has something wrong with it. Try a different digital I/O
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
Unread 23-02-2010, 20:22
Ether's Avatar
Rookie Year: 1969
Yes, use the voltmeter setting, not the ohmmeter.
It's the other way around. 5V means the switch is open; 0V means the switch is closed.
Unread 23-02-2010, 21:03
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
I've been measing 1.69 volts across the switch even when I change the DIO port to another one. Everything else connected to the digital sidecar works even another limit switch that's connected to the DIO. The switch itself has the black and white wires from the pwm cable hooked up to it, with the black wire going above the C and the white above the NO. We'll have to get back to the troubleshooting at competition thursday, but these are great tips thanks!
Also, do you think we should change the Digital Sidecar as mentioned earlier, even though everything else is working? We appreciate everyone's input!
-Meezy
ahhh Division Finalists!!
Unread 23-02-2010, 22:43
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You cut the center wire back and insulated it correct? You are looking for the switch to be wired from the black and white wire of the PWM cable you are using. The pullup to 5 volts when the switch is open occurs via a resistor in the digital sidecar.
Al
WB9UVJ
www.wildstang.org
________________________
Rookie Year: 1998
I think the short answer is yes but you don't care. We were debugging and used this process, and there was definitely a difference in the resistance with the switch open and closed.
Compressor not working. Alexandstein Pneumatics 15 10-02-2010 08:57
Compressor NOT Working (multiple trials already) Noel Pneumatics 10 02-02-2009 18:38
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Stopping a Marquee David66 Website Design/Showcase 6 01-02-2003 22:05
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
