Go to Post I'd hate to state the obvious here...but I believe that we all just got Rick-rolled... - Hallry [more]
Unread 23-02-2010, 22:59
john92 john92 is offline
FRC #1571 (Braughtwurst)
john92 is an unknown quantity at this point
PSI problem
Our system pressure won't go above ~60 psi and the compressor keeps running which waste a lot of battery.
Thanks for the help.
Unread 23-02-2010, 23:02
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: PSI problem
Sounds a lot like the main regulator is installed backwards. The arrow needs to point from the high pressure side to the low pressure side.
With a leak preventing the compressor from getting over 60 PSI you can probably hear it even over the compressor, you may also be able to feel the air from a leak of that magnitude.
Unread 23-02-2010, 23:03
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: PSI problem
Check your pressure relief valve. Most will need adjustment.
Second did you use the correct regulator and is it set properly?
Unread 24-02-2010, 07:31
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: PSI problem
If you have checked the suggestions above and are still having the issue, perhaps the pressure switch and gauges are after the regulator. Double check that you have one gauge prior to the regulator to read high side pressure and one gauge after (or attached to the second port on the regulator) the 60 psi regulator to read low side pressure. If your compressor is running all the time and there are no leaks and the pressure relief valve is not opening, it is likely your compressor is pumping something up to near 150 psi.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-02-2010, 07:35
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: PSI problem
You can wipe soapy water on the pneumatics and look for bubbles to form from leaks. Though the backwards regulator is the most likely culprit.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
PSI in Driver Station kinganu123 Java 1 13-02-2010 16:57
programming pneumatics psi thatoneguy23 Programming 6 28-01-2010 09:46
Greater than 60 PSI LH Machinist Pneumatics 9 12-01-2010 18:21
120 psi penguain Pneumatics 12 11-02-2008 20:41
Trackball PSI pumbaa2007 General Forum 2 12-01-2008 19:39
