Go to Post An awesome unveiling video is not necessarily an indicator of onfield performance. - ToddF [more]
Unread 08-03-2010, 02:25
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: So, who has a custom dashboard?
Originally Posted by slavik262 View Post
As many of you know, I'm currently in the process of making one. I've ran into a roadblock though. After working with the UI for several weeks, I went today to test the networking only to find that FIRST had completely changed the protocol around. If anybody could get me up-to-date documentation on the dashboard protocol, I would be extremely grateful.
I don't believe it changed much... what are you thinking changed? I know we added in the error data that shows up on the dashboard and the made a distinction between high- and low-priority dashboard data. If you have any more direct questions about it, just PM me.
Unread 08-03-2010, 06:54
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
Rookie Year: 2007
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
They didn't completely change it around - that was me being a bit reactionary and frustrated that it changed when I went to test it. The user data used to be in the following order: User string (as in a string of text you could add), Error string, and then the rest of the user data. This is in contrast to the current setup with high-priority data, then the error string, then the low-priority data. I have it working (to my knowledge anyways - I still need to do some more testing with the robot) thanks to Eric Haskins and his documentation. You can check out my first release at the bottom of this page. There's a few bugs in the initial release that I noted on page 4 -they're already fixed and I'll have the next release out in a day or so.
Unread 15-03-2010, 14:31
Rookie Year: 1997
The primary change was to rename the fields. Because user strings and user data are both just variable size data fields, we didn't think they should be named as though they would only work in those ways. Since the real difference was the priority of each field wrt to the error strings, we decided to name it as such. Then on the robot, we made it easier to send either strings or packed data to either field. Make sense?
What was the practical difference that impacted your code?
-Joe
Unread 15-03-2010, 16:36
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: So, who has a custom dashboard?
We have a custom dashboard of which the main purpose is to reduce lag and increase the size of the vision
Expect the best, Prepare for the worst
Unread 04-03-2010, 22:44
tutkows1's Avatar
tutkows1 tutkows1 is offline
FRC #2077
tutkows1 is an unknown quantity at this point
How do you make the custom dashboard look for the camera feed?
Unread 05-03-2010, 18:58
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
should you be able to get the camera feed with just a specialized java swing image container?
Unread 05-03-2010, 23:19
Joshuaal2000 Joshuaal2000 is offline
FRC #0131
Joshuaal2000 is an unknown quantity at this point
For my team, I am Using the Demo Dashboard as a base, but I have completely modified it to only contain info that our drivers want during the match, such as two bars to compare our what our drivers set for our kicking distance, to that of what the robot is currently set to kick at. This makes it simple for the drivers to see when the Kicker is in the correct position. We have Booleans for certain necessary features. We also display What state our Autonomous and Kicker state machines are currently in, Using enumerations from our C code.
Originally Posted by Alan Anderson View Post
Our custom Dashboard works great. We're using LabVIEW on the robot, so it was easy to make the data match up.
One wrinkle we added was to split the display into two tabs. One is for use during a match and the other has a lot of diagnostic information (like raw encoder counts and other sensor input).
I have also done this to my dashboard, but in a different fashion. Using Data sent from the robot, we have made an autonomous and a teleop tabs plus a developer tab for debugging. During the match, the tabs switch from auto to teleop instantaneously when the state of the game changes with no manual control needed. This allows us to display different data during each part of the match, and allows us to keep our auto tab uncluttered so we can have larger text and inidcators, so that the driving team can view it from their starting position. The developer page requires manual opening to view.
Unread 24-02-2010, 11:04
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
We have a custom dashboard and a programmer that's diving into some more of the advanced features like animating shapes and creating custom indicators.
One thing that we haven't figured out completely yet is if it is possible to access the Teleop Elapsed Time without sending it from the 'bot. We're going to use this data to flash an indicator when we are approaching the final 20 seconds of the match.
Do I have to send that time from the 'bot, or is it already available via some local Dashboard/DriverStation variable that we haven't found yet?
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 24-02-2010, 16:55
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
tried to make a custom dashboard, but got so confused on how to. i looked up some videos on frcmastery.com but they jump around from one series to the next, so i didnt get it.
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 24-02-2010, 17:38
PIDman's Avatar
PIDman PIDman is offline
Chuck Dickerson's Scapegoat
AKA: Will Ballard
FRC #0456 (Siege Robotics)
Rookie Year: 2010
PIDman is an unknown quantity at this point
Ours isn't really custom, we just tweaked it a bit. We have an indicator to convert psi into kicking distance, it's really neat.
Unread 24-02-2010, 19:22
pSYeNCe's Avatar
pSYeNCe pSYeNCe is offline
Programaster
AKA: James
FRC #2010 (Lightning Bots)
Rookie Year: 2007
pSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to behold
We have a (non-tested) custom dashboard for extra feedback, mostly. I wish I had more time with the robot, I would customize it a lot more than I did... Ah well. There's always the practice day before competition!
Unread 24-02-2010, 20:50
PranavSathy PranavSathy is offline
Team Captain
AKA: Pranav Sathyanarayanan
FRC #0263 (Sachem Aftershock)
Rookie Year: 2010
PranavSathy is an unknown quantity at this point
We have a custom dashboard in C#, and it reciees packets via TCP/IP to display certain values like voltage, it shows a live camera feed AND it even records whatever images we got after a certain record packet is sent. It also has audio playback capability to play cool music during certian points of the match like a victory and game over music.
Below is the picture of our dashboard at startup
Unread 26-02-2010, 19:52
1 * 4 != 14
Rookie Year: 2007
can someone please send me a link to the protocol notes that FRC/WPI used to make the dashboard? I want to make my own dashboard in python/pyGtk, I am programming the robot in java.
Unread 26-02-2010, 22:29
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
We've done quite a bit of customizing. Bigger vision window, orientation compass, kicker strength indicator, status lights. Simplified the overall look for easy viewing. Pretty easy when using Labview to program.
Custom Dashboard Yppiz FRC Control System 1 17-02-2010 22:45
Custom Dashboard Yppiz Java 1 17-02-2010 12:27
Custom Dashboard writchie FRC Control System 7 02-03-2009 20:21
Custom Dashboard - Visual Basic Mike Lat Programming 3 23-01-2005 14:26
Custom dashboard program available. Interest? archiver 2001 4 24-06-2002 00:45
